SVT Forums
Heads, Block Compatability
Old Feb 22, 2008 | 08:50 PM
jlw2387's Avatar
jlw2387
Default Heads, Block Compatability
Hey what heads and blocks were the same for different year cobras? i.e. is a 2001 block the same as a 2003 and so on. Also are there any other cars that shard the same heads or block.
Old Feb 22, 2008 | 08:59 PM
Blownsvt's Avatar
Blownsvt
Default RE: Heads, Block Compatability
they are not the sam blocks except the 03-04 cobras. the heads should be compatible for all years of the cobra from 99-04. not 100% on the head interchangability but fairly certain. maybe someone else will chime in.
Old Feb 22, 2008 | 10:42 PM
limp1969's Avatar
limp1969
cast block in 03-04 my guess would be porting or valve size maybe different for 99-04 but would still bolt up
Old Feb 23, 2008 | 06:57 AM
ponysnake99's Avatar
ponysnake99
96-98 usedthe teksidblock and b series heads, first 60-70% of 99's used thesame teksid block as the 96-98, but then switched to awindsor block. the other30-40% of99's share thewindsor blockwith the 01's, and all 99-01 share the same tumbleportheads. 03-04 uses the same block as the GT but has a newer (and the best long term production mustang) head style than the 99-01's. heads should match up fine. cam lobes, intake angles and other small tweaks differ these heads in order to broaden the power curves, nothing drastic. but so no one connects the two, this interchangability is not how they became "modular" engines.
Old Feb 24, 2008 | 10:49 AM
Black*Death's Avatar
Black*Death
I have a 99. Told heads are a bit of a problem on 99 but not sure of reliability of 01. The 99 head problem is why the Mach 1's came out with stronger heads(aka longer bolts possible improved gasket). I am having my 99's ported now by MMR in CA due to "leaking" of head gasket
Old Feb 24, 2008 | 05:50 PM
Ehmark's Avatar
Ehmark
All 96-04 4.6 and 5.4blocks are compatable with all 96-04 cylinder heads.
Old Feb 24, 2008 | 06:23 PM
AJ06GT's Avatar
AJ06GT
You'll learn just about anything you want to know by reading this: http://en.wikipedia.org/wiki/Ford_Modular_engine
GimpyHSHS
19
Dec 19, 2023 01:12 PM
mustangheaven
Jan 3, 2016 11:20 AM
mustangheaven
Sep 29, 2015 11:00 AM
junior04
Sep 28, 2015 10:53 AM
wraith777
Sep 28, 2015 10:49 AM
