SVT Forums
Engine bay screech...help
Old Feb 29, 2008 | 07:23 AM
iraziel's Avatar
iraziel
Default Engine bay screech...help
My bro has a Termi and just replaced the belt back to the 8 ribbed, it was running on a 6 rib for 2 weeks. Every time it goes above 3k RPM it makes a screeching/ squealing sound.
There are a couple of other factors to consider:
1.The original 8 rib wore off 2 ribs because of an idle pullyoff alignment. But car was purchased in that condition, after car was ran for a while the wear on belt was noticeable. While the car had the 6 rib on it, it was ran hard from time to time.
2. The car went from NM to CA for a month, then back to NM (here now)
Any help is appreciated...thanks ahead of time
Old Feb 29, 2008 | 08:33 AM
ZAXJAX's Avatar
ZAXJAX
Default RE: Engine bay screech...help
Sounds like one of the idler bearing are bad. Put belt dressing on it and see if that stops it.
Billet Flow make a nice set of idlers you can buy.
Nick Oliver
Oct 17, 2018 04:22 AM
AmericanMuscle4.6GT
Nov 10, 2015 02:06 PM
rksnow1
Sep 14, 2015 08:46 PM
showoffzx2
4 Cylinder NA and Turbo
Sep 14, 2015 08:40 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
