SVT Forums
leaking rear end
Old Mar 12, 2008 | 06:14 PM
limp1969's Avatar
limp1969
Default leaking rear end
Anyone else had this problem 15k on it you think it would be solid. Been dripping/
I am guessing there is no gasket? How hard is it/ should be simple but you never know? What kinda of friction oil do you use?
Thanks for your help dudes
Old Mar 12, 2008 | 07:04 PM
Blownsvt's Avatar
Blownsvt
Default RE: leaking rear end
sounds like a cracked diffeentilo cover to me, soame thing happened to mine. there is no gasket, it is acaulk type sealer that is out on the cover when installed. if it is infact cracked the only fix is to replace it. mine just had 2 tinyhairline cracks in i, but it was slowly leaking.
Old Mar 12, 2008 | 08:36 PM
baino's Avatar
baino
royal purple and redline are both good fluids. Also, not being an @ss, but did you check the bolts on the cover. I say this because I had one try to back out because after the gear swap, I didnt let the lock tight sit long enough.
Old Mar 12, 2008 | 09:28 PM
redeye's Avatar
redeye
I ♥ Acer
i never seen a irs cover that didnt leak[&o]
Old Mar 12, 2008 | 09:55 PM
Blownsvt's Avatar
Blownsvt
mine never leaked ever until it cracked
Old Mar 13, 2008 | 02:06 AM
limp1969's Avatar
limp1969
Anybody no the torque spec? i will check that first
Old Mar 13, 2008 | 09:36 PM
Blownsvt's Avatar
Blownsvt
i would just see if there are any that seem looser than the rest. if it is leaking through a crack you might be able to see it.
Old Mar 13, 2008 | 09:41 PM
antiv6's Avatar
antiv6
there is one brand of cover that is stronger, has an irs brace type thing built in, id search for that on svtperformance
Old Mar 13, 2008 | 09:47 PM
redeye's Avatar
redeye
I ♥ Acer
getthe irs cover brace if you are going to reseal it .
Old Mar 14, 2008 | 01:35 PM
limp1969's Avatar
limp1969
thanks dudes
Tyoung68
Aug 25, 2015 04:31 AM
inyadreems
Aug 21, 2015 09:10 AM
91StangOwner
Aug 20, 2015 11:34 PM
Black_GT_02
Aug 20, 2015 01:26 PM
92 5.0stang
Aug 13, 2015 06:46 AM
