SVT Forums
clutch cable
Old Apr 29, 2008 | 02:44 PM
cobra96fp's Avatar
cobra96fp
Default clutch cable
i have a 96 cobra. i have to replace the clutch cable at least once a year. i figured i might have it adjusted too tight but i have even put the stock self adjusting quadrant back in, it has actually helped some but they are still breaking. any suggestions? i was also wondering about a hydraulic clutch system, if possible? are hydraulic systems slower than a cable?
Old Apr 29, 2008 | 02:51 PM
RuffCat's Avatar
RuffCat
Default RE: clutch cable
once a year? You must b buying crap cables, because I have the origional one on my car and it has 76kmi on it. Sounds like you have a diff problem and is causing your cable to break. Possibly bad adjustment causing you to over extend your cable and/or a bent clutch fork which has happened before.
Old Apr 29, 2008 | 02:58 PM
cobra96fp's Avatar
cobra96fp
could be crappy cables but it also broke the stock one a few years back. my car has 160K miles, tremec 3550, lakewood bellhousing, stock fork, fordracing clutch, but the cable is breaking under the dash always within an inch or two of where it hooks into the quadrant
Old Apr 29, 2008 | 06:20 PM
Ehmark's Avatar
Ehmark
Are there any sharp things under the dash that could be slowly wearing away the cable?
Old Apr 30, 2008 | 02:27 PM
cobra96fp's Avatar
cobra96fp
no, ive put the stock plastic quadrant back in, i figured it would wear before the cable, ive checked it since and there arent even any plastic shaving to indicte wear
Old Apr 30, 2008 | 11:53 PM
secretz's Avatar
secretz
I've heard that there's A LOT of problems with aftermarket clutch cables. I've read off of the SVTPerformance forums that the OEM one is the way to go.
Old May 1, 2008 | 01:47 AM
Ehmark's Avatar
Ehmark
I have a steeda/ upr clutch cable setup and it works great.
Thunderball
15
Nov 22, 2015 11:49 PM
kevsgt
Oct 9, 2015 10:12 PM
breaking
Oct 2, 2015 01:27 PM
Explosive
Oct 2, 2015 07:45 AM
junior04
Sep 28, 2015 10:53 AM
