SVT Forums
squikiness, whats it from
Old May 8, 2008 | 09:36 AM
758cobra's Avatar
758cobra
Default squikiness, whats it from
i dont know if anyone else has had this but my clutch just started doing this but it wines when i touch it. t stopped part way through the day but if it comes back how do i fix it
Old May 8, 2008 | 10:40 AM
Jazzer The Cat's Avatar
Jazzer The Cat
Retired Moderator
Default RE: squikiness, whats it from
This may be just thebearing making contact with press. plate and beginning to spinor possiblya failing throw-out bearing. Does the sound happen just as the clutch is pressed, and stop immediately? Does the clutch pedal vibrate or feel funny otherwise?
Jazzer, like #6, looking for information......information
Old May 8, 2008 | 10:56 AM
BlOwNsNaKe's Avatar
BlOwNsNaKe
ORIGINAL: Jazzer The Cat
+1 I had the same problem at one point and it was the bearing.
Old May 8, 2008 | 09:45 PM
758cobra's Avatar
758cobra
when its pressed, just a touch could do it, i havnt gotten it all the time just periodically. no vibration or funy feelings
Old May 8, 2008 | 09:46 PM
758cobra's Avatar
758cobra
if that is the case how much does a bearing cost
Old May 9, 2008 | 07:30 AM
Jazzer The Cat
Retired Moderator
If it ONLY makes a little "squeel" when you first press the clutch, sounds like it is just the bearing spinning-up from a stop upon contact with pressure plate. If the clutch feels OK otherwise, wouldn't worry about it much. To replace the bearing, it would be best to just do a clutch at the same time. It is not much more money, and to pull the trans. is quite a little job.
Jazzer
zeromancer
Mar 25, 2008 02:37 AM
