SVT Forums
03 cobra engine problems - any ideas?
Old May 14, 2008 | 09:28 PM
4.0stang's Avatar
4.0stang
Default 03 cobra engine problems - any ideas?
Hey guys. I got an 03 termi with some trouble. I was getting in my cobra the other day and noticed antifreeze leaking on the parking lot. Looked like it was coming from the heater core (passenger side with a few drops inside the car too). I couldn't go very far before it started heating up (I kept a close eye on the temp gauge). I had to stop and let it cool down a few times before I could make it to the shop to be fixed. The weird thing is that although it leaked all that antifreeze, the reservoir stayed full. After a week of working on it that included changing the heater core, new thermostat, pressure testing the cooling system for leaks, checking radiator flow and checking the water pump and lines, and the fan is working but it stillruns hot! Not only does it run hot now, at around 3000 rpms, my cobra starts jerking and loosing power! Not cool at all. Basically they didn't know what else to check so I had to take it to Ford today to get it looked at. Any ideas anyone?
Old May 14, 2008 | 11:29 PM
Does Not Exist's Avatar
Does Not Exist
Default RE: 03 cobra engine problems - any ideas?
Damn, that's a doosie of a cooling problem. Hope Ford can figure it out.[]
Old May 16, 2008 | 04:32 PM
lazyeye's Avatar
lazyeye
could be a blown headgasket
Old May 16, 2008 | 07:09 PM
bugpack28's Avatar
bugpack28
ok. You have to perge the coolent system whenever you let any of the coolent. The is a quarter inch drive bolt on the drivers side of the supercharger, its black and capping off a steel black line about an inch around. That bolt is the highest point in your cooling system, not your coolent tank. Most of the time there are large air pockets that can run through the system causing your car to overheat. As for the power loss, its just your computer knowing that you are running hot and retardes the timing and cuts the boost. Things to check are; that bolt, your thermostat (they can be bad get a 180 degree one), coolent level, and make sure your fans are on. Thats about it. Good luck
Old May 17, 2008 | 11:04 AM
xxkazp3rxx's Avatar
xxkazp3rxx
+1.. and when you burp the system (what above is describing) sometimes you have to do it multiple times on these cars... they're pains in the ***.
Old May 17, 2008 | 08:19 PM
bugpack28's Avatar
bugpack28
Also everytime you overheat you have to burp it. When the coolent boils that little pocket gets filled up with air.
Old May 17, 2008 | 09:00 PM
Olivarez's Avatar
Olivarez
good luck!
Diode Dynamics
28
May 26, 2022 12:02 PM
Nexuia
Aug 23, 2015 11:30 PM
kdryan
Aug 21, 2015 04:01 PM
KEM Motorworks
Aug 14, 2015 10:13 PM
drumhedd2005
Aug 13, 2015 09:59 AM
