SVT Forums
Pulley Mod Questions
Old Jun 10, 2008 | 08:30 PM
nxcess00's Avatar
nxcess00
Default Pulley Mod Questions
Ok thinking doing a pulley mod for my 03 cobra...
What is everyones suggestions ?
And should i do new a Idler Pulley Kit a Blower Belt Tensioner ?
Whats the best manufacture of the above products that I should use ?
-Thank you everyone for your help ! This forum is great !
-Nxcess
Old Jun 10, 2008 | 08:36 PM
xxkazp3rxx's Avatar
xxkazp3rxx
Default RE: Pulley Mod Questions
I didn't buy my pulley, nor do i know the manufacturer name.. but i always recommend a 2.81... reason being, is that you're not really losing much boost if any by staying at a 2.81 vs 2.76, but you won't have as much pulley slip... I never had any slip with my 2.81... You could always do a 2.93 with a 4# lower pulley... your hp numbers won't be as high, but your tq will improve and give you a better power curve all around.....
Old Jun 10, 2008 | 09:14 PM
Blownsvt's Avatar
Blownsvt
i always reccomend billet flow pulley do the 4pc idler set as well. it is worth it. for an unported blower i would got with a 2.76 as that will give you the most gain.
Old Jun 11, 2008 | 06:24 PM
xxkazp3rxx's Avatar
xxkazp3rxx
less then 1 psi difference between the 2.81 and the 2.76, but a whole lotta extra heat....
ORIGINAL: Blownsvt
Old Jun 11, 2008 | 06:39 PM
antiv6's Avatar
antiv6
id get the 2.76, i have no belt slip at all
Old Jun 11, 2008 | 08:34 PM
562cobra's Avatar
562cobra
what about the 2.65 from reichard racing or some name of some sort?
Old Jun 11, 2008 | 09:16 PM
antiv6's Avatar
antiv6
if i did it again id probably do the rr one for a bit more power, with all the bad posts about lower pulleys breaking cranks id go with the smallest upper you can
Old Jun 11, 2008 | 09:40 PM
562cobra's Avatar
562cobra
the 2.65 will add how much psi on top of stock?
Old Jun 12, 2008 | 01:05 PM
2k6silvergt's Avatar
2k6silvergt
ORIGINAL: 562cobra
Probably 7-8 psi more.
Old Jun 12, 2008 | 01:08 PM
2k6silvergt
I would go with billetflow upper and idlers. Do a 2.76 if you are just doing an upper or a 2.93 and 4lb lower.
