SVT Forums
timing chain broke
Old Jun 18, 2008 | 12:24 PM
Flake6899's Avatar
Flake6899
Default timing chain broke
Just wondering if the timing chain breaks on a 01 cobra do the pistons touch the valves?
Old Jun 18, 2008 | 01:09 PM
USMCrebel's Avatar
USMCrebel
Mach I Section Moderator
Default RE: timing chain broke
why would it?
not trying be an *** just walk you through the internals.
Old Jun 18, 2008 | 01:38 PM
Flake6899's Avatar
Flake6899
I dunno on another forum a guy said that the cam may not spin as its suppose to and the crank might still spin so the pistons can move up while the cam is closed and a valve may still be down....I'll check it out though.
Old Jun 18, 2008 | 01:42 PM
Ehmark's Avatar
Ehmark
it can happen.
Old Jun 18, 2008 | 03:30 PM
USMCrebel's Avatar
USMCrebel
ORIGINAL: Flake6899
if the chain breaks being that our vehicles are over head cam, yes it is more than possible, if this has happened you need to fix it ASAP or bad things will come very shortly.
Old Jun 18, 2008 | 06:35 PM
Jazzer The Cat's Avatar
Jazzer The Cat
Retired Moderator
I had a '72 Vegawith an overhead cam with a belt. It slipped a couple teeth one day after school and designednot hit the valves (less than fantastic compression ratio, as you may have guessed [&:]). I have little doubt that the pistons will hit on a Cobra. This is one of the reasons it has a chain instead of a belt. Risk is low, but damage would be high.
Jazzer
Old Jun 18, 2008 | 11:40 PM
Ehmark's Avatar
Ehmark
The cobra engine is an interference design I broke all of my exhaust valves on my gt engine.
Old Jun 20, 2008 | 09:03 PM
bugpack28's Avatar
bugpack28
+1 to the guy above me your going to hit... Take it apart!!!
mungodrums
Oct 7, 2015 04:01 AM
StalkerGT
Sep 25, 2015 02:41 PM
cbird1177711
Sep 2, 2015 04:12 PM
