IN STOCK- NEW!! Fore Precision Works 99-01 Cobra Fuel Rails
We're proud to announce the arrival of the Fore Precision Works 99-01 Cobra/03-04 Mach-1 High Flow Fuel Rails!!
IN STOCK WITH SAME DAY SHIPPING!!
http://www.lethalperformance.com/pag...uel-rails.html
Made specifically for the 99-04 Naturally Aspirated 4V's these rails offer fit and finish above and beyond any other fuel rails offered on the market.
Fore Precision Works Fuel Rail Features:
-OEM positioning, orientation, and size of o-ring seats for injectors.
-Robust bolt on mounts for safe and reliable injector seating. Stainless steel mounting hardware included.
-Fuel Rail Pressure Sensor Mount. -FRPS bank includes a 1/8" NPT fitting for remote fuel pressure sending units for in car fuel pressure gauges. Optional block-off available for return style systems.
-Auxilliary connection bank has provisions for locking down a Kenne Bell restrictor orifice for FRPS replacement without fear of losing restrictor orifice.
-Unique low profile design clears inlet of twinscrew superchargers. Overall rail height is the same as the OEM rails WHILE providing a 56% larger bore than the stock fuel rails.
-SAE o-ring boss ports (-8 size) on front and back of both rails.
-Front of rails is truncated to maximize clearance in the front of the rails. Aft of rails are positioned to maximize flexibility of supply/crossover lines.
These fuel rails are machined from 6061-T6511 from a solid block of aluminum. There are no welds or caulk to fail.[/align] __________________
Diode Dynamics
28
05-26-2022 12:02 PM
