SVT Forums
Tire Question
Old Jul 13, 2008 | 04:55 PM
bigjay01cobra's Avatar
bigjay01cobra
Default Tire Question
Need help.....I am looking to purchase new rear tires for my 01 Cobra. I am currently running Nitto 285s on a 18x10 American Racing wheel. I am wondering if I can go wider without any rubbing. Any help would be appreciated! Thanks!
Old Jul 14, 2008 | 12:48 PM
OzzDOA's Avatar
OzzDOA
Default RE: Tire Question
You can probably get away with 315's without rubbing on 18's, especially if the car is lowered. The main problem is the IRS subframe bolt. If you look carefully when the suspension is loaded that bolt head isinside the diameter of an 18" rim.
Old Jul 14, 2008 | 06:13 PM
Jazzer The Cat's Avatar
Jazzer The Cat
Retired Moderator
I don't know of a 315 rated for a 10' rim, but I am sure it would fit.With that said, I DON'T recommend one as it is toolarge weather it is rated or not, IMO.Thereis a guyon this forumd that ran315's on 10.5' rim and believe they were on 18' wheels without a problem.
Look back post by post beginning about 3 weeksago and you will find it. At the time, there were about 5~6 posts about IRS and 10.5' wheels.
Good luck.
Jazzer
Old Jul 14, 2008 | 08:34 PM
Hegotgame's Avatar
Hegotgame
i would think for anything above a 295 you would want a 10.5
Old Jul 28, 2008 | 04:33 PM
562cobra's Avatar
562cobra
im lowered about 2inches and barely got 285/40/17 to clear the irs bolt. this is on stock 17x9 rims on the rear. so im pretty sure if i would of gone 295 i would of bolt rubb.
mtgldr
Feb 3, 2024 09:00 PM
mmarsh3014
Wheels & Tires
Oct 20, 2015 09:08 AM
Sep 8, 2015 11:50 AM
raleigh05GTO
Sep 4, 2015 07:09 AM
