SVT Forums
slow cranking
Old Aug 3, 2008 | 02:08 AM
superbean's Avatar
superbean
Default slow cranking
Car 98 cobra -
Problem - when i turn the car over, it will roll 5-6 times before it fires.. is this a common thing for mod motor starters to spin slow? The motor does have 120k miles on it.
I'll do a resistance check and voltage drop from there. Perhaps the fuel pump isn't priming enough before i crank it.
Old Aug 3, 2008 | 02:25 AM
Mustang3GT07's Avatar
Mustang3GT07
Default RE: slow cranking
Before you start it, Turn the key all the way on (dont start it ) Let all the lights come on the dash, wait 5 seconds then start. See if that helps. This way you let the fuel pump kick on first, also by doing this the life of your fuel pump will last longer.
Old Aug 3, 2008 | 07:36 AM
SVTeeshirt's Avatar
SVTeeshirt
i think 96-98s have problems with fuel pumps cutting out, mine did, not cool.
Old Aug 3, 2008 | 01:02 PM
superbean's Avatar
superbean
I let the fuel pump prime longer, rolled over on the 2nd try! I'm used to it since i had a highflow walbro pump in my nissan.
4cylinderplus2
Oct 9, 2020 07:45 PM
svfetter
Oct 5, 2015 11:39 AM
KingRando
Oct 1, 2015 11:16 AM
RCS02v6
Sep 29, 2015 01:46 PM
Wombatnation
Sep 13, 2015 09:16 PM
