SVT Forums
o2 sensor
Old Aug 20, 2008 | 06:12 PM
my94pony's Avatar
my94pony
Default o2 sensor
how hard is it to change the o2 sensors on a 96 cobra, where exactly are they located
Old Aug 20, 2008 | 07:45 PM
Jazzer The Cat's Avatar
Jazzer The Cat
Retired Moderator
You will have 4 of them. Two on the motor-side of the cats, and two after. They are easy to remove/install provided you have enough room to get your hands in there. The upper front ones (specifically the passenger side) is usually the hardest to reach as they are tucked up toward the manifolds. The rears are after the cats and before the mufflers and should be parallel with ground and pointed at each other.
Do you know which one is bad?
Jazzer
Old Aug 21, 2008 | 09:00 PM
my94pony's Avatar
my94pony
i know which one is bad i need to run the computer again n look up the code i forgot
jwog666
Dec 27, 2021 08:09 PM
mrtrodonet
Sep 19, 2020 03:12 PM
Dathan
Oct 5, 2015 05:52 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
TfcCDR
Sep 14, 2015 12:08 PM
