SVT Forums
1996 cobra fuel pump problem
Old Sep 22, 2008 | 11:42 PM
sprayncobra's Avatar
sprayncobra
Default 1996 cobra fuel pump problem
I am having issues with my fuel pump install on my 96 cobra. I upgraded my fuel pump to a Walbro 255, after installation the fuel pump kicked on once I turned the key, and that was the last time it pumped. there is no fuel pressure at the rails. I have done the following....
-replaced fuel filter (installed correctly)
-checked all lines
-checked fuses
-checked fuel pump inertia switch
-replaced relay (located behind glove box)
-pulled pump, tested, and functioning properly
-checked and there is no power going to the pump
Does anyone know what the problem could be?
Old Sep 23, 2008 | 10:52 AM
contentsunderpressur's Avatar
Follow your wires from the pump back to the front of the car. You may have pinched them somewhere. Check for power coming from the relay. If you have power then you know you have a bad wire going to the pump somewhere.
Old Sep 23, 2008 | 11:35 AM
sprayncobra
Thanks i will try that tonight.
mstahoo
SVT Forums
Aug 19, 2021 09:15 PM
Design1795
Jan 24, 2017 10:38 PM
Design1795
Aug 24, 2015 04:41 PM
drumhedd2005
Aug 13, 2015 09:59 AM
89blueslug
Aug 10, 2015 07:20 AM
