SVT Forums
Installing Head cooling mod
Old Sep 25, 2008 | 10:51 AM
sirlammy21's Avatar
sirlammy21
Default Installing Head cooling mod
This is the one I found and wanted: http://www.lethalperformance.com/pag...oling-mod.html
I called a performance shop near me and they said that no matter what you will have to remove the supercharger which takes 2 hours to take off and another 2 hours to put on. They also said it will take 4 hours to install this alone not including take off and putting on the supercharger. So they say 8 hrs in total and they charge $99/hr. Also getting a thermostat put on they said it will be another hour so basically its looking like $125.00 for the cooling kit, $25 for the thermostat, and about $900 in labor. Does this seem right and if so is it even worth it? $1050 for just this installation seems like alot to me but let me know what you think. Thanks
Old Sep 25, 2008 | 11:08 AM
Timspony's Avatar
Timspony
SVT Section Moderator
I'd get an estimate from a different shop...time & rate both sound high...maybe you can find someone on that works on the side.
Old Sep 25, 2008 | 11:58 AM
Blownsvt's Avatar
Blownsvt
that labor rate is spot on dollars per hour wise. i think the time estimate might be a little high though. i don't see it taking 4 hrs to install a head cooling mod.
Old Sep 25, 2008 | 12:06 PM
Timspony's Avatar
Timspony
labor rate around here in upsate NY is $72 at local shops....maybe higher at a dealership though!
Old Sep 25, 2008 | 03:44 PM
562cobra's Avatar
562cobra
it states on the site that it can be installed with the supercharger on and without removing the tranny. i'd look for a shop that works specifically on mustangs. if not, why not try it your self? i'll probably end up doing mine when i order.
Old Sep 25, 2008 | 04:32 PM
Blownsvt's Avatar
Blownsvt
labor here at the shop i ususally use is 90 or so. at the biggest speed shop around here it is 130 an hour.
Old Sep 25, 2008 | 06:10 PM
Mustang3GT07's Avatar
Mustang3GT07
lol thats funny because I bought the same one and installed it myself. I never had to remove the supercharger. Took me about 2hrs and thats with a lunch break.
Old Sep 25, 2008 | 10:20 PM
Hegotgame's Avatar
Hegotgame
I was gunna have one put on last week but i needed my car back to run it on saturday but they told me burping the coolant is the hardest part of the install. Also here in Michigan the shop i get all my work done at is only 65 an hour..
Old Sep 26, 2008 | 12:02 AM
562cobra's Avatar
562cobra
lol at OP after reading this.
Old Sep 26, 2008 | 08:32 AM
sirlammy21's Avatar
sirlammy21
How do you install it? Is there directions anywhere? I know nothing about fixing or working on cars so would it still be possible for me to do it?
