SVT Forums
coolant/antifreeze
Old Oct 15, 2008 | 11:58 AM
cohhbra's Avatar
cohhbra
Default coolant/antifreeze
what the best coolant to antifreeze ratio for termi's, and some people were talking about distilled water, can you really put water in an engine, it seems like it would boil?
Old Oct 15, 2008 | 12:57 PM
562cobra's Avatar
562cobra
yes water has to be mixed with antifreeze, 50/50 mixture, then, poured into the coolant tank. And distilled FTMFW
Old Oct 15, 2008 | 01:06 PM
mfj's Avatar
mfj
Banned
Wow... What a question coming from a Cobra owner? Just FYI, its always good to mix distilled water with antifreeze. And as for water boiling? Since the whole system is under pressure, the boiling point of water in the system is drastically increased...
Some people have had good results using a mix of 50% antifreeze, 24.9% water, and 25.1% waterwetter...
Old Oct 15, 2008 | 03:12 PM
cohhbra's Avatar
cohhbra
so don't get the 50/50 coolant/antifreeze mix from advance auto, just do 50% distilled water and 50% antifreeze or it that what that pre-mixed stuff is?
and could you do like a 70/30 mix to bring it down or does it HAVE to be 50/50?
Old Oct 15, 2008 | 03:54 PM
mfj's Avatar
mfj
Banned
It needs to be 50/50...
Technically, water has much better "cooling" effects, but you need to do a 50/50 mix....
Old Oct 15, 2008 | 04:35 PM
Timspony's Avatar
Timspony
SVT Section Moderator
...I'm not concered about the mixture, I'll mix 50/50 with some water wetter...But what about the air pockets with these Cobra's cooling system? ...I asked this question months ago and got no post...
Old Oct 16, 2008 | 07:13 PM
jlg32281's Avatar
jlg32281
I don't have a Termy, but I do have a lot of experience disregarding anti-freeze mixture suggestions from the manufacturer. A lot depends on the climate the car will be exposed to. We are headed into winter, so if you park your car outside and it freezes hard, you need anti-freeze, but you definitly don't need 50%. If you park in a garage, and the garage itself never freezes (which most garges never come close), you don't really need any anti-freeze. Water is the best disipator of heat, the more water you use, the cooler it will run. Water Wetter or a similar product will increase the natural dissipating characteristics of water. I don't run any anti-freeze in any of my vehicle, but I'm in Texas where it hardly ever freezes. You cannot run water without anything in it. You have to put some anti-freeze or Water Wetter for the lubrication and corrosion resistance. If I were you, seeing you're in VA, I would run a 10% anti-freeze, Water Wetter (or similar product), and distilled water.
Old Oct 17, 2008 | 04:15 PM
Timspony's Avatar
Timspony
Anyone on "burping" your Cobra?
Old Oct 23, 2008 | 09:43 PM
jlg32281's Avatar
jlg32281
I'm not sure how different the 03-04 cobras are, but on mine, I just fill it through the crossover tube with the overflow cap off util it fills to the correct level, then cap the overflow and fill the crossover until full. That's all I've ever done and never had a problem.
Old Oct 24, 2008 | 09:34 AM
Timspony's Avatar
Timspony
Thank you for the information....
94EatonStang
Oct 15, 2013 06:17 PM
Stangs4Life
Feb 10, 2007 05:06 PM
