SVT Forums
99 COBRA QUESTION
Old Nov 10, 2008 | 05:50 PM
300Z5's Avatar
300Z5
Default 99 COBRA QUESTION
okay i have a 99 cobra siting in my garrage, i have took the motor out because of a recent breakdown, i might have blew a rod or shot a piston,
i was planing on buying a 5.0 stroker kit to stroke it to a 302, but im not sure if the crank shaft, rods, and pistons would work out on my car
give me some ideas
Old Nov 10, 2008 | 06:07 PM
silverstang1996's Avatar
silverstang1996
I believe if you get a full stroker kit it should come with the crank, rods, pistons you would need. They are quite expensive.
Old Nov 10, 2008 | 06:16 PM
mfj's Avatar
mfj
Banned
Yeah, you need the whole 302 stroker assembly, which comes with rods, pistons/rings, crankshaft, rod and main bearings, etc...
Old Nov 10, 2008 | 06:25 PM
300Z5's Avatar
300Z5
thank you so if i was to put a 5.0 stroker kit in my 4.6 block get the sleeves replaced for 5.0 it would would run fine as in no compression problems or anything, and will it work fine with a cobra motor
Old Nov 10, 2008 | 06:36 PM
mfj's Avatar
mfj
Banned
There is no need for change in bore for a 302 stroker... For a 5.1L, get the block bored .20 over and get 5.1L pistons... And we have no idea what shape your heads and valvetrain is in... so no answer for the compression results..
Old Nov 10, 2008 | 06:39 PM
300Z5's Avatar
300Z5
well its a stock 99 mustang cobra the ratio i think is 9.85:1
Old Nov 10, 2008 | 07:37 PM
mfj's Avatar
mfj
Banned
That all depends on the kind of pistons you use... You have to specify what compression ratio you are looking for, when you order your pistons... the dish/bowl will vary, depending on what you want...
Nov 10, 2015 11:39 AM
Ipaman
Sep 22, 2015 07:01 AM
04stangman
Sep 17, 2015 01:45 PM
Sparks_88
Sep 8, 2015 01:06 PM
