SVT Forums
anyone with 600 rwhp ?
Old Nov 20, 2008 | 05:15 PM
neverenough's Avatar
neverenough
Default anyone with 600 rwhp ?
ok i got a 03 cobra , with kennebell 2.6 and a sra with 3.73s , with 315 nitto r's , my problem is i cant get no traction now. i was wondering if swap to a 3.27 gear would help.
any owners with 600 rwhp and 3.27s ?
the 3.73 spin 1st and second gear are useless now.
it appears to me that it runs through the gears way to quick.
im not sure how much more shudder it will give me with the 3.27s , when i had the stock 3.55s it shudder i bit , 3.73s no shudder.
i really dont run it at the track its more a crusier ,but i would like to hook better, it feels as if it was faster all stock.
Old Nov 20, 2008 | 06:13 PM
Timspony's Avatar
Timspony
SVT Section Moderator
Stock Suspension? ....3.27's should help, but 600hp, you're going to spin the wheels in colder weather.
2000AZ5.0GT's Avatar
2000AZ5.0GT
I would have said to stick with the IRS, I swapped to an 01 Cobra IRS and spent a little on suspension and it hooks like a dream, but yeah, I'm using a centri blower and running a 3.55's and I wouldn't suggest anything higher, so I think with the KB you might want to look at a set of 3.31:1 gears, they might be a good compromise
Old Nov 20, 2008 | 06:44 PM
neverenough
no irs for me. to many failures, even with the good stuff .
i got put some eibach rear drag springs on it with the right side airbar , and spins on nittos.
hey i got a sweet 03 cobra with a 2.6 k/b with 19 psi boost, heres what i got
BA#2400
single blade TB
60 Lbs injectors
K/N fipk
gt pumps, twin lethal hat twin fpdm's with fuel line upgrade. and no bap
Old Nov 20, 2008 | 08:45 PM
mfj's Avatar
mfj
Banned
Wow... This thread is full of fail... Even with 3.27's, traction is going to be a B!TCH!! That's what happens when you have 600+ rwhp on a PD blower powered cobra... Throttle control IS your best friend, in the first 2 gears...
Old Nov 20, 2008 | 09:02 PM
neverenough
i hate throttle control .i dont like back peddling
Old Nov 20, 2008 | 10:19 PM
philla10's Avatar
philla10
i just got some mickey t street drag radials and the hookup like a dream.. best purchase i have made for mine.
Old Nov 20, 2008 | 10:29 PM
neverenough
i got these 315 nittos on 17x10.5 cobra rims. i was looking for a tire that was good in the rain , this is my vaction or going out of town car mostly. so i didnt want to get stuck in the rain .
i wanted hoosier dr's 315s on a 17 in rim. but not good at all in the rain.
i found on my other car that even the stickest et streets dont hook on the street, they only hook at the track ,in the pre heated sticky rubber .
Old Nov 21, 2008 | 08:55 AM
Timspony's Avatar
Timspony
...Mickey's really not meant for the streets, let alone the rain! ....Sounds like you need to tune the suspension to match your HP...
Old Nov 21, 2008 | 09:32 AM
neverenough
my rear has mega bite lowers bolt on bottom hole and adjustable uppers , sperical upper bushings with eibach drag lauch springs with air bag. i need to make less power i think or sand bag it.
