SVT Forums
Termi fuel upgrade q's
Old Jan 18, 2009 | 06:03 PM
avexhype's Avatar
avexhype
Default Termi fuel upgrade q's
1.How much rwhp can a bone stock termi fuel system support?
2. What do most 03/04 cobra guys do for fuel upgrades for the ones that do KB/Whipple upgrades and push around 6-700rwhp?
3. Also, how much more hp can a termi STOCK fuel system support by adding a KB BAP alone?
edit: my question pertains to the fuel rail and BACK (dont mind the injectors or MAF; just the tank, pumps, lines, etc)
Old Jan 18, 2009 | 06:07 PM
Blackvenom01's Avatar
Blackvenom01
www.kennebell.com that place has all the info and tech articles you need and more also has dynos sheets etc....
Old Jan 18, 2009 | 07:36 PM
avexhype's Avatar
avexhype
ok cool so 700 rwhp with JUST a BAP
Old Jan 18, 2009 | 08:09 PM
Blownsvt's Avatar
Blownsvt
no way you would at a minimum neer a bap and injectors. no way will the stock 39# ers get you anywhere near 700.
Old Jan 18, 2009 | 11:11 PM
Mustang3GT07's Avatar
Mustang3GT07
Alot of questions you are asking, you planning on buying a Terminator soon? lol.
Old Jan 18, 2009 | 11:20 PM
SVTeeshirt's Avatar
SVTeeshirt
You wouldn't know anything about that.
im working on my E-Sarcasm, how is it?
Old Jan 19, 2009 | 02:36 AM
antiv6's Avatar
antiv6
for above 500 rwhp you will need bap, injectors, and a new maf unit either diablo or sct. With those you should be good for a twin screw
Old Jan 19, 2009 | 09:18 AM
avexhype's Avatar
avexhype
I should rephrase my question- a stock termi fuel system from the fuel rail and BACK (the tank to the rails). I know injectors arent good for much over bolt-ons on a termi. And i already have a PMAS blow-through MAF thats good for 800+ rwhp.
so actually, no i dont plan on buying a termi- what for i already have a vortech 2v
This is for my current car- a 2000 gt. Right now im running an svt focus pump with 42lb lbs and at 444 rwhp the fuel system still had more room to play with.
My main concern is supporting fuel for this summers build which should be around 600 rwhp. I know ill have to upgrade injectors, but my concern is if i get this termi tank/pumps what upgrades do i need to do to it to support the 600-700 rwhp ill have.
I was told the cobra tank and dual pump fuel hat should support this set-up but i need to know what upgrades i need to do to that ONTOP of just the basic tank/pumps.
Old Jan 19, 2009 | 01:23 PM
Blownsvt's Avatar
Blownsvt
in that case just the Bap should get you over the 600 mark. One question though. why go to the cobra pumps/tank? the svt focus pumps are stronger and can likely get you to that mark with no bap at all. Or for about the cost of the bap and probably less you could get gt supercar pumps that will also get you to that range.
Blownsvt's Avatar
Blownsvt
i know nothing of the sort.
