SVT Forums
IRS brace??
Old Feb 4, 2009 | 11:17 AM
  #31
Timspony's Avatar
Timspony
SVT Section Moderator
The brace is recommended if you do a lot of drag (or street) racing...
Old Feb 4, 2009 | 12:45 PM
  #32
pitmitch910's Avatar
pitmitch910
Originally Posted by timspony
the only thing I can tell you is...go look back there, not a lot of room & a bunch of stuff (brackets)! ...I'm not sure about the 3 hours myself, that's my question!
+ how do you change gear fluid?? ...almost have to remove the carrier as far as I can tell...or pump out the fluid!
i think changing the gear oil is the same as a solid rear axle, remove the drian and fill from the driveshaft side, im not real sure on this one
Old Feb 4, 2009 | 01:16 PM
  #33
Blackvenom01's Avatar
Blackvenom01
well i dont do alot of racing but from how you and other put it still seems like i would need it...i ordered it last week thinking it was the bracket and itll be in tom so ill look at the directions and see how much we really have to do to get it on...should i also get the brackets??? i guess i can answer that myself as a yes to stop or reduce wheel hop
Old Feb 4, 2009 | 01:23 PM
  #34
Timspony's Avatar
Timspony
NOT true with an IRS! IRS has the fill plug on the Cover!
Old Feb 4, 2009 | 05:26 PM
  #35
Timspony's Avatar
Timspony
I found this on SVTPerformance http://www.svtperformance.com/forums...irs-brace.html
Old Feb 4, 2009 | 06:42 PM
  #36
pitmitch910
haha oh yea i didnt think i was correct one that one
Old Feb 4, 2009 | 07:02 PM
  #37
Blackvenom01
that was a good write up from svtperformance thanks for that...so should i get the irs brackets also
Old Feb 4, 2009 | 08:10 PM
  #38
MAD SVT's Avatar
MAD SVT
ya.... uhmmm..... screw that....
Looks like a legit 3 hours, you could prob get this done in less than an hour if you had a lift at your convienence
As for Mike and his 1 car garage??? ya.. I'll have my shop throw it in there next time its in there... material and labor probably 250..
but thanks for the info, you've sold me on the idea.
Old Feb 4, 2009 | 08:14 PM
  #39
Blackvenom01
ya i got a lift too thank good like you said prolly an hour
Old Feb 5, 2009 | 07:03 AM
  #40
Timspony's Avatar
Timspony
...we'll see how it goes in a few days!
