SVT Forums
Clunking in rear
Old Feb 10, 2009 | 09:43 AM
jimbos99cobra's Avatar
jimbos99cobra
Default Clunking in rear
I noticed a clunking sound/feel from the rear of my 99 while shifting gears.. or if im cruising and step on it alittle I can hear/feel it. Is that normal for the IRS??
Could it be a bushing issue??
I am new to the Modular 4.6 and IRS scene so any help would be great.. thanks
Jim
Old Feb 10, 2009 | 10:21 AM
OzzDOA's Avatar
OzzDOA
You have the good 'ole "Cobra Clunk". Its basically driveline slop from the soft rubber bushings that Ford used for NVH reasons. The first step would be to install poly or aluminum diff bushings and work from there.
Old Feb 10, 2009 | 10:58 AM
Blackvenom01's Avatar
Blackvenom01
If not that it could be too much slack in the driveshaft ive seen it happen in trucks many times
Old Feb 10, 2009 | 11:11 AM
03svtcobra12's Avatar
03svtcobra12
i have it also, its the bushing and other IRS issues, doesn't hurt performance though
Old Feb 10, 2009 | 04:52 PM
562cobra's Avatar
562cobra
You need 14mm bolts put on where Ford put in 12mm bolts on the IRS.
Old Feb 10, 2009 | 05:38 PM
jimbos99cobra
14mm diameter or length??? How do I check for slop in the drive shaft??
Im glad it doesnt effect peformance.. I was worried that the rear may fall out on me
Old Feb 10, 2009 | 07:42 PM
OzzDOA's Avatar
OzzDOA
That's only an 03/04 thing. The 99's and 01's didn't have that problem.
Old Feb 10, 2009 | 08:53 PM
MAD SVT's Avatar
MAD SVT
i had that same clunking sound... til i let the hooker outta my trunk.. lol
ya mine makes that sound too, kinda freaks me out, but i have the whole "please break, i wanna upgrade" mentality so i just ignore it haha
Old Feb 11, 2009 | 11:20 AM
jimbos99cobra
IS this the proper set to replace the Diff bushings??
http://www.steeda.com/products/cobra...l_arm_bush.php
Old Feb 11, 2009 | 12:19 PM
OzzDOA's Avatar
OzzDOA
Those are control arm bushings, while they will help stiffen the IRS this is what you want:
http://www.steeda.com/products/cobra_diff_bushings.php
