SVT Forums
Low boost
Old Mar 9, 2009 | 04:13 PM
562cobra's Avatar
562cobra
Default Low boost
Let me start off by saying that when I had the car dynoed, my psi went max to 9.99, or if you wanna call it 10. There were no mods done to the car other than a mac intake, the reason it isn't boostin 8 psi.
THE PROBLEM
While in WOT in 1st, it doesn't boost to where it should. Needle stays in the 6-7 area. My RPM also climb slow like. Shift to 2nd and I get near the same results. 3rd gear is where I get full boost and feel the car pulling and pinning me to the seat.
I searched google and found that I may have to have it re-flashed. Other than the intake, I have added a catless x pipe and a bassani catback.
Now my question is, what do you guys think is wrong?
Also, how much will a re-flash run me?
I have no plans in doing any pulley swap at the time.
Old Mar 9, 2009 | 04:21 PM
Timspony's Avatar
Timspony
SVT Section Moderator
...Belt slipping? ...I would wait on the re-flash & get it done with the pulley change...What plugs/gap you running?
Old Mar 9, 2009 | 04:31 PM
562cobra's Avatar
562cobra
ngks stock gapped.
if I do a pulley change, wouldn't I need a dyno tune instead of a re-flash?
Old Mar 9, 2009 | 04:36 PM
Mustang3GT07's Avatar
Mustang3GT07
Originally Posted by 562cobra
ngks stock gapped.
Yes you should get a dyno tune but if your really low on cash I know Tim has a guy that does like mail order tunes that is really good. Hopefully he can tell you more.
Old Mar 9, 2009 | 04:38 PM
Timspony's Avatar
Timspony
I'm also running the NGK TR-6's....Re-gap them to 0.032"....Pulley change you will need to get some kind of tune/flash! ....I'm not sure if you have a tuner, but that's the route I'd go...If you're going to use the stock lower, go with a 2.76" blower pulley!
Old Mar 9, 2009 | 04:40 PM
Timspony's Avatar
Timspony
...Going to MustangMagic in Long Island, NY in April....I plan on swapping to the 2.76" blower pulley! ....Flat fee, $400...as many pull's as it takes to get my Cobra right!
James at RWTD can help you with mail Cobra tunes!
Old Mar 9, 2009 | 04:54 PM
562cobra's Avatar
562cobra
As for the plugs, don't I need to re-gap them only if the car is pullied?
Atleast that is what I have come to learn.
Edit: soon to be pullied.
Old Mar 9, 2009 | 04:58 PM
Timspony's Avatar
Timspony
I've been running SC's for a long time & I've always liked a tight gap (so you don't blow out spark)....Pullied = more boost = more air!
Old Mar 9, 2009 | 05:35 PM
CobraBob's Avatar
CobraBob
Tim is right about tightening up the gap. Although you should be fine with the stock gap if you're using the stock upper pulley. I know tuners in CA aren't as plentiful depending on where you're located. Sounds like you have a tuner in mind. Where and who? Assuming your tuner knows his stuff, you will likely get your boost issue ironed out during your dyno tune. And in your case I'd definitely recommend a dyno tune vs. a mail order tune. For obvious reasons. Be sure to buy at least one auxiliary idler if you're going to swap to a 2.93 upper or smaller. I highly recommend the smaller pulley with the dyno tune. You're going to pick up a minimum of 50rwhp. And a HUGE smile. You'll wonder why you didn't do it sooner. :-)
Old Mar 9, 2009 | 06:55 PM
Blownsvt's Avatar
Blownsvt
here is my question..... why do you think you need a reflash if all you have is exhaust mods? honestly it sounds more like belt slip to me. you seeing a belt dust on the blower or pullies at all?
