SVT Forums
Cams
Old 03-25-2009, 09:41 AM
03svtcobra12
03svtcobra12's Avatar
Default Cams
question # 1How hard is it to install a new set of cams, with new springs, retainers, the works?
im think something like these
http://www.lethalperformance.com/03-...4-cobra-p-1141
Not going to do anything immediately just trying to figure out what direction I want to go with the car, dont say, if you dont know how dont do it, I'll have some friends help me I am going to do EVERYTHING to the car myself,
question #2 are cams worth doing if im not going to build the entire motor? i know the gains wont be near what i could get from a twin screw but I really love everything about a car with a nice set of cams
03svtcobra12 is offline
Old 03-25-2009, 09:53 AM
MAD SVT
MAD SVT's Avatar
its a PITA, just removing the valve covers is pretty tricky and time consuming.
either way your going to end up pulling the motor off the mounts, i'd suggest just lifting it out the car all together.
MAD SVT is offline
Old 03-25-2009, 12:37 PM
Mustang3GT07
Mustang3GT07's Avatar
I'd say its worth it, so go for it. You won't get the full benefit from them untill you go twin screw or atleast a PP eaton, but you will deff notice a power increase. Nothing more fun then having a bunch of friends help lol it will be a good time.
Mustang3GT07 is offline
Old 03-25-2009, 12:42 PM
Xemeth
Xemeth's Avatar
You don't have to pull the motor off the mounts, and definately not out of the car, although it makes it a lot easier.
I'm in the middle of doing it right now. Whether or not you can do it depends on your mechanical ability. Are you comfortable with timing a DOHC engine? How about degreeing the cams?
Xemeth is offline
Old 03-25-2009, 03:06 PM
SVTeeshirt
SVTeeshirt's Avatar
+1 to the last 2 thing Xemeth said, thats gonna be the hardest part, Timing + Cam Degreeing.
SVTeeshirt is offline
Old 03-25-2009, 07:16 PM
MAD SVT
MAD SVT's Avatar
i'd really love to see ya get a valve cover off a 4V with the wiper motor in the way.
mine was just done last week
MAD SVT is offline
Old 03-26-2009, 09:23 AM
Xemeth
Xemeth's Avatar
As long as the hydro-boost and master cylinder are out of the way the valve cover comes off quite nicely. You can even sneak it by the clutch cable if you're good.
If you can get the rear valve cover off of a 4.6 Northstar in a Cadillac DTS, you can get the valve cover off anything, lol.
Xemeth is offline
Old 03-26-2009, 11:55 AM
pcs
pcs's Avatar
i hate those northstar v-8
pcs is offline
Old 03-26-2009, 08:53 PM
Ehmark
Ehmark's Avatar
It is much easier to remove the engine and swap the cams that way.
Ehmark is offline
Old 03-26-2009, 09:44 PM
Xemeth
Xemeth's Avatar
Try working at a ****ing Cadillac dealer. They pack them in tighter and tighter every year. You can get the valve covers off in the car, but the motor has to come out to do a head gasket.
Xemeth is offline
Quick Reply: Cams
