03/04 Cobra Fuel Pumps
I put in a new 04 Cobra fuel pump hat/assembly on my 2000 GT a couple weeks ago. I also upgraded my wiring from this writeup:
http://www.modularfords.com/forums/s...ad.php?t=23656
(Basically 10G wire from battery to a relay to the FPDM then 10G wire from FPDM to fuel hat)
I am putting a blower on next weekend and am wondering how much hp (please specify RWHP or flywheel) this will support? Thanks.
I thought it was around 500 rwhp but shouldn't it be more with the wiring upgrade?
I am using 60 lb/hr injectors with a SCT BA3000 MAF sensor. Aftercooled Vortech V1 with a 3.1 pulley. I might be pushing it close with these pumps right?
ya you would need to use that FPDM as a companion to a Boost-A-Pump, as for now, your FPDM is just allowing your car to push those Cobra pumps. and the STOCK pumps are only good until about 475.
adding a boost a pump will allow your current setup to go like 600, if your looking for more power than that, you should have probably used the Ford GT pumps.
I will eventually get GT pumps with dual FPDMs or a modified FPDM. But I want to get this car done this weekend. So it seems these pumps, even with all the upgraded wiring, will support 475-480 rwhp. In his first paragraph, the guy who wrote the wiring upgrade article in my OP said that his wiring upgrade is somewhat of an alternative to a BAP that's why I thought it should handle 500+ rwhp.
I don't think I'll be that high but I'll definately be a little over 400 rwhp. I will definately monitor fuel pump duty cycle on datalogging for a little while.
