SVT Forums
Cobra...SCT question...
Old May 1, 2009 | 06:16 PM
Timspony's Avatar
Timspony
SVT Section Moderator
Question Cobra...SCT question...
SCT question: If you play around with the parameters on a tune before you upload to the car (tweak the timing, etc.), the next time you upload it, does the tune return to the stock parameters that tune had?? ...or does it keep the same "adjustments" I made??!!
Also, Can I use my SCT xcal2 to scan other Ford OBDII cars while it has a tune (etc.) on my Cobra??
....Thanks
Old May 1, 2009 | 11:01 PM
03svtcobra12's Avatar
03svtcobra12
are you changing the parameters on the tuner? if so when you reload the tune there is an option to keep the parameters youve changed or use the non-adjusted ones thats on my SF3 though, and no idea about scanning codes
Old May 1, 2009 | 11:50 PM
NotStok's Avatar
NotStok
Yes you can use the Xcal to read trouble codes on any other Ford OBDII car. I had to use mine to read the codes on my Ex's Cougar while my GT was tuned. It's only locked for performance tuning.
Old May 2, 2009 | 07:36 AM
Timspony's Avatar
Timspony
Thanks ^^^^ ....can you laso use the SCT to clear the codes?
Old May 2, 2009 | 01:16 PM
NotStok's Avatar
NotStok
Yup, you can.
Old May 2, 2009 | 03:17 PM
Timspony's Avatar
Timspony
Again, Thanks ^^^^
Dalthius
Jan 19, 2006 03:56 AM
Scooterman
May 12, 2005 11:44 AM
black89gt
Mar 12, 2005 08:08 PM
SCARFACE
SVT Forums
May 6, 2004 05:12 PM
karma279
Oct 27, 2003 07:18 PM
