SVT Forums
96 Cobra problem :(
Old Jun 27, 2009 | 02:22 PM
my94pony's Avatar
my94pony
Unhappy 96 Cobra problem :(
When my car is in gear it feels like the car is stuttering. I've changed the oil, fuel filter, and spark plugs. It was feeling better after I did this but now it's as bad as it was when it started. This all happen after running seafoam through the car. Any ideas?
When I ran the seafoam I put a third (of the bottle) in the oil, third in the gas tank and a third in the vacuum line. I drove around with about a third tank of gas for a little bit after this before filling up. I'm not sure if this has anything to do with it.
Old Jun 27, 2009 | 09:15 PM
my94pony's Avatar
my94pony
it also threw a code ... p0430 which is an 02 sensor, anything guys im really pissed off driving this car right now anytime i puch on the pedal a lil bit it stutters and its very annoying to drive
Old Jun 28, 2009 | 02:17 AM
ekthrilla's Avatar
ekthrilla
which vaccum line did you put it in? did you put it to where it goes before any sensor. it sounds like a MAF sensor problem to me. my 98 was doing some stuttering and a lil lunging so i cleaned my MAF sensor, IAC, And Throttle Position sensor and it stopped doing it. but when you put the seafoam into your oil, and by putting it into the vaccum, it causes the seafoam to go all the way to your valves which is a good thing but it could have broken up some garbage and just needs to be flushed out. im just throwing things at you. i need a lil more details about when exactly it started and what you did before it started.
Old Jun 28, 2009 | 07:27 PM
my94pony's Avatar
my94pony
well there shouldnt have been much garbage to break up the engine only has 10k miles on it, idk im bringing it to my mechanic tuesday to figure it out
Old Jun 28, 2009 | 09:01 PM
Smokin04's Avatar
Smokin04
Since the engine threw a 02 sensor code...did you replace the sensor???
Nov 10, 2015 11:39 AM
TorinoCobra070
SVT Forums
Sep 18, 2015 10:34 AM
Scottyboy187
SVT Forums
Sep 13, 2015 10:23 PM
rdog69t
SVT Forums
Sep 13, 2015 06:16 PM
Sparks_88
Sep 8, 2015 01:06 PM
