still getting some belt slip
ok so i was at the track 2 weeks ago and after a few runs i noticed some belt dust on the inside of the upper idler, i have the metco idler setup it as the 90mm on the upper and 100mm on the lower if i remember right i couldnt put the 100mm on the upper and i dont think i can get a belt thats just a 1/4" shorter the next size down will probly be too short. looking for some other options, i know i can run a bigger crank pulley but i was talkin to a few guys at the track and they said they were having better luck with the stock sized crank pulley.
also anyone ran the hpp 2 step launch control or similar was also thinking about putting one on for a bit more consistency thoughts on that?
id rather not put the tensioner under that kind of load unless i have to, not only are you risking runing the tensioner but also the bearings in every other idler pulley on that belt, last resort i will try to run the next size down but i i think the tensioner bottoms out against the stop.
autoedit
Sep 27, 2015 06:37 PM
Sep 8, 2015 11:50 AM
