SVT Forums
Clutch upgrade time...
Old Jul 19, 2009 | 07:49 PM
Saleen9300's Avatar
Saleen9300
Default Clutch upgrade time...
Well, I was hoping to not have to do this for a bit, but the car has a mind of its own.
I've been noticing a lot of slipping and now I'm having a hard time getting into first gear. As soon as a I put full length subframe connectors on I've noticed more clutch slippage, which is interesting.
The care came with a Centerforce that was never intended to handle the power the car is making, so I expected this day would come rather soon.
I am pretty much 100% decided on a McLeod RST.
Wondering if I should upgrade to the 26 spline input shaft while I am at it and also get a brand new flywheel, if so, aluminum or steel?
Any suggestions/recommendations?
Old Jul 20, 2009 | 02:42 PM
jimbob8915's Avatar
jimbob8915
IMHO your stock input spline should be fine if your under 500hp 500tq, unless your drag racing with slicks. I have a Mcleod RST sitting in my garage and a new friction plate for my McLeod chromemolly flywheel waiting to go in when I FINALLY get my cooling mod in. I have been waiting 2 months for it to come in as it has been backordered. Do you still have your stock flywheel? They can be rebuilt. I got my RST clutch through Summit for $700 but I will be reusing my flywheel
Old Jul 20, 2009 | 03:20 PM
562cobra's Avatar
562cobra
If you have the money, I would upgrade to a 26 spline input shaft. I just finished doing my clutch/flywheel swap 2 weeks ago and went with a RAM billet steel flywheel and a spec stage 3 clutch kit w/ a centerforce tob. I didn't go with a 26 spline because money was an issue. I was set at the McLeod rst also, then wanted to go with a centerforce dfx, but I ended up going with a spec stage 3. It grabs plenty good for my taste. Like already stated, you can rebuild your stock one. McLeod is the maker of it and charge under 200$ to rebuild it. Shipping will be on you though which shouldn't be much. I would stick to aluminum. Reason I went with a billet steel was cause of cost.
I would say rebuild your stock flywheel, and get the McLeod RST. I have an extra pilot bearing sitting around if you want to replace yours, let me know and I'll ship it out to ya for free.
Old Jul 21, 2009 | 12:56 AM
Saleen9300's Avatar
Saleen9300
That would be great, I would be forever indebted to you.
I will PM you my address.
I ended up going with new Spec flywheel, the RST, a new TOB and retainer sleeve, and a Liberty 26 spine input shaft.
Old Jul 21, 2009 | 01:28 AM
562cobra's Avatar
562cobra
i got your pm i will find a package for it and ship it out tomorrow. when i got my clutch from ebay nib, the seller sent me a ford pilot bearing. which i didnt know til after i ordered mine. are you going to be doing the install? if you look a couple pages back, youll see my clutch thread.
PaulH2
20
Jan 31, 2016 09:48 AM
Thunderball
15
Nov 22, 2015 11:49 PM
Boostaddict
Lethal Performance
Oct 1, 2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
Oct 1, 2015 08:57 AM
junior04
Sep 28, 2015 10:53 AM
