SVT Forums
Throttle Sticking
Old Nov 15, 2003 | 07:04 PM
95cobragirl's Avatar
95cobragirl
Default Throttle Sticking
i have a 95 mustang cobra 5.0 302 with 90,000 miles on it...its frequently hard to start in the morning and the throttle sticks every once in awhile...any ideas...im fresh out...ive replaced quite a bit and still hasnt solved the problem...thanks
Old Nov 17, 2003 | 01:17 AM
Need4SpeedPSR's Avatar
Need4SpeedPSR
well ya can have a few things here....</P>
</P>
first the starting problem</P>
1. Have a ever changed ur fuel fillter? i had the same problem on my GT. I chaged the fillter and it was fine.</P>
2. Cold starts in the morning? Old battery maybe? try that</P>
3. Ever chaged your spark plugs? try that</P>
</P>
as for the sticking throttle....</P>
my gt did that too...</P>
1. get down there w/ a flash light and see if the peddle it self is looking ok. There should be 2 clips on the back of it. On my gt the top clip brook and made it stick when i riped it...</P>
2. Check the throttle body when your car is off. Open and close the t/b a few times to see if the linkage is ok...</P>
</P>
IF all else fails get some1 to look at it...</P>
</P>
GOOD LUCK </P>
keep me posted</P>
Old Nov 18, 2003 | 04:23 PM
95cobragirl
thanks i will definitely check it all out, jenna
Old Nov 18, 2003 | 09:46 PM
nostang's Avatar
nostang
Does the throttle stick open or closed? If it sticks closed,you need to clean out the throttlebody where the throttle blade closes down against the body,there will be some sludge in there that can be cleaned with carb cleaner,just hold the throttle open by hand and spray. hope this helps,
Old Nov 18, 2003 | 11:17 PM
Need4SpeedPSR
sure thing. Let me know how ya make out
Old Dec 29, 2003 | 06:47 PM
Eddie's Avatar
Eddie
Use throttle body cleaner. AsI think carb cleaner will hurt the injectors.
Old Dec 30, 2003 | 02:25 PM
primetime5.0's Avatar
primetime5.0
clean out the air bypass valve
UrS4
Oct 3, 2015 06:23 AM
BeatnikFink
Oct 1, 2015 08:00 PM
guitarman376
Sep 30, 2015 05:54 PM
wraith777
Sep 28, 2015 10:49 AM
JDWalton
Sep 24, 2015 08:47 PM
