SVT Forums
What gears for turbo 96-98 cobra
Old 08-30-2009, 08:30 PM
FrankenStangNPD
FrankenStangNPD's Avatar
Default What gears for turbo 96-98 cobra
I'm actually looking into getting a 96-98 cobra 5 spd. soon and so far my plan is to add a t70 turbo, tubular k-member, coilover conversion, centerforce clutch and of course the supporting mods for the turbo. My question is what gears should I get to replace the 3.27's? With turbo do I need numerically higher gears to help with low end turbo lag since the engine is already weak in the low range or will the engine respond well and allow for 3.73's.
Considering the following gears: 4.10, 3.73, 3.55 or 3.90
FrankenStangNPD is offline
Old 08-30-2009, 09:24 PM
hot sauce
hot sauce's Avatar
327s or 355s
hot sauce is offline
Old 08-30-2009, 09:35 PM
FrankenStangNPD
Originally Posted by hot sauce
327s or 355s
are you saying they come with 3.27 or 3.55 or are you saying thats what i should go with?
Old 08-30-2009, 09:47 PM
hot sauce
hot sauce's Avatar
thats what you should go with
Old 08-30-2009, 10:42 PM
P.S.I.cho
P.S.I.cho's Avatar
kinda depends on your horsepower and setup most turbo cars run 3.55's
P.S.I.cho is offline
Old 08-31-2009, 01:51 AM
FrankenStangNPD
Why are alot of people on here going with 3.73 and 4.10? I'm a little confused. Does the turbo require less gear? By the way the car will be raced at the 1/8 mile track and also a daily driver.
Old 08-31-2009, 08:26 PM
P.S.I.cho
P.S.I.cho's Avatar
most people on here are running N/A setups and yes a turbo/blower can generally use less gear. im not familiar with an 1/8 setup so the 3.55 maybe wrong :S
Old 09-04-2009, 05:26 PM
pcs
pcs's Avatar
you could go lower on a eighth mile track but if you do freeway driving you gas mileage will suck. another big thing will be based on how much hp u plan on running like psicho mentioned.
pcs is offline
Old 09-08-2009, 09:41 PM
Ehmark
Ehmark's Avatar
From what Ive read on here, Turbo cobra's like much less gear because turbo's run off load and not off engine rpm. Less gear would mean more load.
Ehmark is offline
Old 09-11-2009, 01:40 PM
evo eater
evo eater's Avatar
with a turbo car you dont need that low of a gear cause you have the turbo kicking in at certain rpm (and when it kicks in hang on!!). so if your turbo is spooling at 3400 rpm and you redline at 6000 rpms your not gonna get that much from the turbo cause your gonna be shifting so fast. so if you go with a 3.27 gear you will get more out of each gear and be able to get more from the turbo.
evo eater is offline
Quick Reply: What gears for turbo 96-98 cobra
