SVT Forums
BATTERY RELOCATION
Old Sep 2, 2009 | 11:44 PM
300Z5's Avatar
300Z5
Default BATTERY RELOCATION
okay im wanting to place my batter in the trunk, i need somone to tell me how it needs to be done, iv heard that i can ground the negative to the body in the trunk, and iv had somone tell me that i need to take that negative all the way from the trunk to the block, anyone got a pictured graph of how it needs to be done, seems a little confusing, the reason i dont know this is because my motor has been out for about 10 months and i basicly forgot how it went. thanks let me know
Old Sep 3, 2009 | 12:38 AM
300Z5's Avatar
300Z5
bumpss
Old Sep 3, 2009 | 08:03 PM
pcs's Avatar
pcs
u dont have to run the neg all the way to the front. i just grounded it in the trunk.
Old Sep 3, 2009 | 08:05 PM
pcs's Avatar
pcs
the pos. cable has to be ran back up front. just remember that some tracks require u to have a remote battery kill switch accessible from the outside of the car if you battery is moved from the stock location.
Old Sep 6, 2009 | 11:15 AM
1bdhrse's Avatar
1bdhrse
I wish i owned a cobra...but i relocated my battery in my 01 mustang gt using the summit racing nhra compliant battery relocation kit. I took the negative and drilled through the body and grounded it on a rear bumper bolt under the cover. the positive i ran to the starter it fit really nice. i then took all of the wires up front where the old battery was and combined all the grounds. I then cut the positive connector which went to the old battery location back where it connected to the fuse panel right behind the old battery location. i then threw a new connector on that one and put it to the fuse panel where it originally was. so basically that wire goes from the starter to the fuse panel. i mounted the box and ran the positive wire creatively through the frame and along the bottom of the car. there is a vent tube which is pretty self explanatory how to mount. I hope that this was helpful for you and that i explained it well enough. Oh and i used thermal shrink covering stuff around all the connections to give it that professional look. I am not going to lie, it took me a while to do. I try to be a perfectionist even though it prob does not look that good. i do not have pictures but if you want them i will get you some. if you have any questions i will answer to the best of my ability for ya.
-matt
BOB ROME
Jul 26, 2023 01:54 PM
4cylinderplus2
Oct 9, 2020 07:45 PM
baddog671
Jul 26, 2016 01:20 PM
flash_xx
Oct 16, 2015 07:23 AM
logan409
Sep 26, 2015 07:43 PM
