SVT Forums
engine knock!!!
Old Oct 20, 2009 | 05:11 PM
mustang90242's Avatar
mustang90242
Originally Posted by Smokin04
Need more details...
Car year?
Engine?
Base timing if a 5.0?
Does the knock happen @ WOT at 2200 rpm or just cruising?
1999 cobra
4.6 all stock
idk if the timing is off.....
Old Oct 21, 2009 | 05:02 AM
Smokin04's Avatar
Smokin04
What does the ticking sound like? Does is sound like a chain rattling? Or does it sound like something else? Does it only happen for a few hundred rpm or does it continue all the way to high rpm? Does it happen at part throttle or wide open?
Old Oct 21, 2009 | 11:19 AM
mustang90242
yes kinda like like a chain rattling
it starts at 2200 rpm and it continues from there
part thorttle
Old Oct 21, 2009 | 11:31 AM
Smokin04's Avatar
Smokin04
Ok...you're detonating. DO NOT KEEP ON IT!!!
What gas are you running? You have too much spark advance down low or not enough octane. I recommend buying 3 or 4 gallons of race fuel and adding it (or Torco at a minimum) until you can figure out what's wrong.
Do you have a Predator or Hand Held tuner?
How long has this been happening?
Old Oct 21, 2009 | 11:46 AM
mustang90242
91 octane
i dont have any tuner
for a month
Old Oct 21, 2009 | 11:58 AM
Timspony's Avatar
Timspony
SVT Section Moderator
What oil you running in the car?
Old Oct 21, 2009 | 12:01 PM
mustang90242
5w-20 valvoline fully synthetic
Old Oct 21, 2009 | 12:04 PM
mustang90242
how do i fix the spark advance? any ideas
Old Oct 22, 2009 | 08:17 AM
Smokin04's Avatar
Smokin04
You're going to have to take it to a tuner or buy a hand held and retard timing...but the only real way it through a tune from a tuner. UNLESS!!! You have a Steeda timing adjuster...it looks like a blue handle thingy on the front of your crank shaft (balancer)...retard timing on that if so equipped.
Old Oct 22, 2009 | 04:41 PM
mustang90242
ok
i took it to a mechanic and he said i have to replace the crankshaft
i dont really trust him....could that be possible ?
