SVT Forums
engine knock!!!
Old Oct 22, 2009 | 04:47 PM
  #21
Xemeth's Avatar
Xemeth
It sounds like trading your fox for this was a mistake and your buddy screwed you over.
Old Oct 22, 2009 | 04:54 PM
  #22
mustang90242's Avatar
mustang90242
freakin a**hole....but at least its a real cobra...i cant really complain trading a fox for a 1999 cobra
Old Oct 22, 2009 | 07:54 PM
  #23
Choppa's Avatar
Choppa
if its a timing thing then u shouldnt have to replace the crankshaft, did he give u an explanation on y he wants to replace that?
Old Oct 22, 2009 | 11:17 PM
  #24
mustang90242
the mechanic said that i shouldnt be driving it. and that i need to replace the crankshaft
Old Oct 23, 2009 | 07:17 AM
  #25
Smokin04's Avatar
Smokin04
The mechanic is an idiot. Just try and drive easily. If it's pinging under part throttle, there is something VERY wrong there. Put race fuel in it immediately. If it still pings (chain rattling sound), then you will need to pull the motor and pull it apart AFTER you do a compression/leakdown test because there is most likely something mechanically wrong. You could have a hole in a piston which would allow the AF mixture through the hole and oil mist into the chamber which means that cylinder would ping all to hell. Compression/leakdown is an immediate neccessity! But don't let the mechanic who told you your crank needs replaced to do it...he's just trying to rob you.
Old Oct 23, 2009 | 09:23 AM
  #26
Blownsvt's Avatar
Blownsvt
take it to a performance shop if possible. specifically one whoe specializes in late model ford efi vehicles if you can. I would not trust a dealer or budget mechanic to tell me what is wrong on a car like that esspecially once it has been modded. It could be your timing but honestly i doubt it because most people don't even notice light pinging unless they are specifically listening for it. Seems odd that your avereage person would hear that noise unless it is masiivly detonating in which case its probably going to need major repair to the internals of the motor. are you 100% sure it is coming from the motor and not a baffle rattling in a muffler or something else?
Old Oct 23, 2009 | 12:32 PM
  #27
mustang90242
yes im sure becuase the noise is coming from inside the engine block
Old Oct 23, 2009 | 12:34 PM
  #28
mustang90242
how much would a compression test cost and leak down test?
Old Oct 23, 2009 | 02:34 PM
  #29
Blownsvt's Avatar
Blownsvt
compression tests are easy should not be too expensive to do. takes about 15 minutes on a 4V ford. you could probably get your self a tester and do it on your own. you probably want 2 people to do it though. one to watch the preasure gauge and one to crank the motor over.
Old Oct 23, 2009 | 04:03 PM
  #30
Timspony's Avatar
Timspony
SVT Section Moderator
+1 ^^^^ ...I think you can still rent the tool!
