SVT Forums
rmps sticking
Old Nov 20, 2009 | 07:08 PM
my94pony's Avatar
my94pony
Default rmps sticking
everytime i come out of gear my rpms stick in between 1200 and 1400 and then finally goes down only after im at a dead stop for a few seconds.
i have done the following:
took off intake and cleaned throttle body
cleaned iac valve
replaced tps
and no luck yet
Old Nov 20, 2009 | 08:10 PM
98CobraSaleen's Avatar
98CobraSaleen
Mine has a similar issue, but seldom is above 1000 rpm. My service manual talks about a relay that reduces fuel pressure at idle and I can hear a distinctive click just before the engine idles down. I replaced the relay when I was troubleshooting a phantom engine shutdown. It is located in the right glove box/kick panel area. If the idle is going down, I would guess it's working.
David
Old Nov 25, 2009 | 12:59 PM
my94pony's Avatar
my94pony
so the throttle body was the problem! friggen ford says not to clean your throttle body they mean it!
Old Dec 11, 2009 | 12:43 AM
pkwest's Avatar
pkwest
You need an IAC restrictor plate. it will reduce the flow of air through the IAC and that allows the engine rpm to drop faster when you release the throttle quickly. Ford use to make iac adjusting plates that went between the IAC motor and the intake.
They don't want you to clean the throttle body because it has a coating that can get damaged.
Old Dec 11, 2009 | 06:34 AM
jimbob8915's Avatar
jimbob8915
Tell us more about these plates. I could easily make one if I knew what size the holes were.
Old Dec 11, 2009 | 11:07 AM
amoosenamedhank's Avatar
amoosenamedhank
ah, that magical search button.
https://mustangforums.com/forum/4-6-...ging-rpms.html
Old Dec 11, 2009 | 01:18 PM
my94pony's Avatar
my94pony
it had nothing to do with the iac, i changed the throttle body and the problem was fixed
BeatnikFink
Oct 1, 2015 08:00 PM
wraith777
Sep 28, 2015 10:49 AM
stealth_GT
The Racers Bench
Sep 22, 2015 02:19 PM
SXGT
Aug 31, 2015 01:28 PM
TCStangerv6
Aug 30, 2015 09:01 PM
