SVT Forums
IRS swap.
Old Dec 19, 2009 | 04:20 PM
JUSTA6's Avatar
JUSTA6
Default IRS swap.
hey guys i just bought a 2004 irs to put in my car after i gernaded the rear in my car thursday morning. supposedly its a complete drop out assembly and i know i need to change the exhaust and the yoke on it, but what i was woundering was can i run a 17x10.5 deep dish bullitt wheel with 315/35/17s on it and clear everything in the rear as far and wheel openings, cradel bolts, control arms, and brake lines and those sorts of things ? your help will be greatly appreciated
Old Dec 20, 2009 | 01:06 AM
Blownsvt's Avatar
Blownsvt
yes you can run a 10.5 inch wheel with no trouble. watch the clearance of the tire on the IRS bolts. you will see the ones i am talking about as they will be right by the sidewall of the tire. you may need to change them our for ones with a low profile head on them. they are only a few bucks. pretty sure you can get them on maximum motorsports.
Old Dec 20, 2009 | 02:50 AM
JUSTA6's Avatar
JUSTA6
ok. does it bolt in with the same bolts as are used to bolt the solid axel control arms into the body
Old Dec 20, 2009 | 10:30 AM
Blownsvt's Avatar
Blownsvt
i am not 100% on that. I seem to remember the hardware being slightly different and also seem to remember there being 2 sets of holes that are there one for the IRS and one if you are using a solid axle. I did the swap the other way from IRS to solid axle. Maybe someone else can chime in to confirm what i seem to remember or say i am off. I did this swap several years ago.
Old Dec 20, 2009 | 12:21 PM
JUSTA6's Avatar
JUSTA6
ok thanks . the swap is being dont cuz the 7.5 in my car gernaded
Old Dec 20, 2009 | 12:45 PM
mfj's Avatar
mfj
Banned
How were you able to grenade that rear, with v6 power? lol
Old Dec 20, 2009 | 03:16 PM
JUSTA6's Avatar
JUSTA6
the 7.5 inch rear was the same rear in the 4 banger mustang. they are very weak . the left carrier bearing exploded and actually split the cage in half and chipped every other ring gear tooth and . with the cage being split it ate up the bearing race so i needed a replacement axel housing too . thursday morning it went bang and felt like the rear was falling out of the car but in all actuallity it had .300+ clearence between the ring and pinion gears
Old Dec 20, 2009 | 04:57 PM
Blownsvt's Avatar
Blownsvt
why do you want the IRS though over an 8.8?
Old Dec 20, 2009 | 05:05 PM
Sxynerd's Avatar
Sxynerd
it's traction not power that destroys rear ends
A common debate irs vs. sra but IRS feels/handles better. No matter if it's a weaker design or not. The key is to them lasting is knowing how to adapt your driving to fit the IRS.
Old Dec 20, 2009 | 05:08 PM
JUSTA6's Avatar
JUSTA6
as far as i know nobody else in the v6 community has one
