SVT Forums
building new motor have some ??s
Old Jan 4, 2010 | 08:33 PM
robert_barnes181's Avatar
robert_barnes181
Default building new motor have some ??s
ok bought a 99 teksid motor runs good 50,000 mile out of lincoln mark 8 i know crank is six bolt and cams r seferent heads have same casting numbers my ? is im running pro charger and am going to up boost going to bore motor 10 or 20 with new forged dished pistons and forged rods is the crank ok to use is only thing 6 bolts verse 8 bolts or is something else about it that is deferent. also can i just change out cams in heads and use the ones from the lincoln ( thinking of a stage two or something ) this way i have motor ready to drop in or do i need to use crank from cobra and heads also
Old Jan 4, 2010 | 11:04 PM
robert_barnes181
im sorry motor is out of 92 lincoln my cobra is 99
Old Jan 5, 2010 | 04:10 AM
JC316's Avatar
JC316
Originally Posted by robert_barnes181
Ok, I bought a 93 teksid motor, it runs good. Came out of a 93 Mark VIII and it has 50,000 miles on it. I know the crank is six bolt and the cams are different than the Cobra. The heads have the same casting numbers. My question is that I'm running a pro charger and I am going to up the boost. I am going to bore the motor out .10 or .20, with new forged dished pistons and forged rods. Is the crank ok to use? Are the 6 bolts verses 8 bolts the only thing different from the cobra?. Also can I just change out the cams and the heads and use the ones from the lincoln? ( thinking of a stage two or something ) this way I will have the motor ready to drop in, or do i need to use crank from cobra and heads also?
You post is kinda confusing, so I rewrote it as best as I could.
Now to answer your questions. First, it's out of a 93, as the Mark VIII ran from 93-98. Use the cobra crankshaft, it's forged, and since it's 8 bolt, you will be able to use the clutch that's in the cobra now. I would also use the heads and intake from the 99 cobra since you definitely don't want to use the 93 Mark VIII intake and the 99 cobra intake won't bolt up to the B heads on the Mark VIII.
firehorse02
Nov 16, 2015 11:28 AM
UrS4
Oct 3, 2015 06:23 AM
Explosive
Oct 2, 2015 07:45 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
logan409
Sep 26, 2015 07:43 PM
