SVT Forums
Oil Leak
Old Sep 27, 2010 | 08:16 PM
AGDProMan's Avatar
AGDProMan
Default Oil Leak
I have rebuilt my 1997 Ford Mustang Cobra SVT. I put in an aftermarket oil pump a Ford M-6600-046 STD is the oil pump. It seems to be leaking at the bottom of the oil Housing towards the engine. When I installed the oil pump, the shaft that hold the oil housing to the engine and the oil filter also screws onto this shaft, Is there a O-Ring in the middle??? I know there what looks to be a slot for an O-ring but the stock O-ring doesnt fit. Any help would be appreciated thanks.
Old Sep 28, 2010 | 05:35 AM
Blackvenom01's Avatar
Blackvenom01
i cant quite figure our where your saying but ive had a similar prob a couple times...there is the engine then oil cooler bracket then oil cooler then your oil filter....there is an oring between the cooler and the adapter and that goes out alot...gotta drain all the oil and your radiator to take it off clean out the canal and get a new o ring....hope that helps man
Old Sep 28, 2010 | 05:19 PM
AGDProMan's Avatar
AGDProMan
okay thanks, ill try that. the leak is so small it has to be an o-ring issue
Old Sep 29, 2010 | 05:29 AM
Blackvenom01
ya the first time it happend to me it was nearly impossible to find cause it was so small and i just couldnt pin point it until it totally blew and you could watch it spray out haha...
4cylinderplus2
Oct 9, 2020 07:45 PM
bradleyb
Nov 27, 2015 07:50 PM
jerrytubes
Oct 23, 2015 12:11 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
wraith777
Sep 28, 2015 10:49 AM
