SVT Forums
99 Cobra Gasket help!
Old Dec 23, 2010 | 03:19 PM
stanglx2.3's Avatar
stanglx2.3
Default 99 Cobra Gasket help!
I am burning some oil in my 1999 Mustang Cobra. I want to replace the valve cover gaskets and spark plug tube seals and grommet. I hope this will solve the problem. I dont have any leaks on the ground, just burning oil out of the exhaust. Does anyone have tips to help me replace the two? Any help would be appreciated. Thanks
This is the link to the gaskets:
http://www.napaonline.com/Search/Det...026070+5999999
Old Dec 24, 2010 | 10:53 AM
Blackvenom01's Avatar
Blackvenom01
i dont wanna sound all negative but sounds more like valve guides, piston rings, etc...i guess it is possible that spark plug tube seals are leakin oil onto plug but unlikely...to get your driver side valve cover off you will have to unbolt the motor mount and jack that side up a few inches...goodluck!!
Old Jan 7, 2011 | 08:55 AM
stanglx2.3's Avatar
stanglx2.3
Ok thanks for your input. I used some Lucas oil additive and I have noticed that I have not burned as much oil. I hope it holds out and I will be switching to high mileage oil to see if that helps.
Old Jan 8, 2011 | 09:38 AM
Blackvenom01
ya thatll work for awhile youll need to readd it each oil change! goodluck man
Old Jan 8, 2011 | 12:39 PM
mfj's Avatar
mfj
Banned
Bad valve cover gaskets and bad tube seals will not result in oil coming out of your exhaust. There is a much more serious issue going on.
Old Jan 9, 2011 | 02:31 AM
ASSEMbler's Avatar
ASSEMbler
Temp fix for sure. You're gonna need a rebuild
Old Jan 9, 2011 | 03:28 AM
uberstang1's Avatar
uberstang1
Chupacabra
Chances are you just need new valve seals.
Old Jan 9, 2011 | 10:50 AM
mfj's Avatar
mfj
Banned
I wouldn't even go that far. It's not even a temp fix.
88 orangepeel notch
Oct 5, 2015 09:03 AM
Dathan
Oct 5, 2015 05:52 AM
wraith777
Sep 28, 2015 10:49 AM
Demodulates
Sep 18, 2015 11:14 AM
EASTIDEE123
Sep 15, 2015 11:08 AM
