SVT Forums
Which twin screw???
Old Jan 5, 2011 | 03:08 PM
Mustang3GT07's Avatar
Mustang3GT07
Whipple!!!
On a side note, MFJ - When are you going to get the new 4.0 Whipple?
Old Jan 5, 2011 | 03:29 PM
mfj's Avatar
mfj
Banned
Originally Posted by Mustang3GT07
Whipple!!!
On this motor? Never. I don't want to break the crank with that much stress on it. If I had a 5. 4 and the money, then I'd do it. They fixed the problem by placing the supercharger drive pulleys inside the accessory belt drive, closer to the block, so that made it less stressful to the crank, not being so far out...
Old Jan 10, 2011 | 03:42 PM
04svtcobra16's Avatar
04svtcobra16
If I went with the 3.4 what other upgrades would I need to do other then the fuel rails? I thought I read the 3.4 is for the motors that had been worked on. I have not cracked my open, and not sure if I want to. The link below is what I am leaning to buy, what do you all think, or do you know any where else I can get a better deal?
http://www.lethalperformance.com/sup...-black-p-12952
Old Jan 10, 2011 | 04:12 PM
mfj's Avatar
mfj
Banned
With the 3.4 Whipple don't go any smaller than a 3.5 pulley (22-23psi) if you want to run pump gas. Any smaller would require better fuel (e85 or race gas). As far as engine modifications, that's not really necessary. The ONLY thing I would highly recommend is welding the crank pulley hub to the crank pulley so that it doesn't start coming out, like other 3.4 Whipple cars have done. When that starts to happen, it starts acting like a press and eventually will **** up your thrust bearings while pulling your crank forward and ruining your engine.
Old Jan 12, 2011 | 02:22 AM
dirtydave289's Avatar
dirtydave289
2.3L Whipple here..and I love it
Old Jan 13, 2011 | 10:11 AM
04svtcobra16
What is your Dyno #'s? with the 2.3?
Old Jan 13, 2011 | 01:55 PM
dirtydave289
It made 561 @ 14#'s and 593/556 @ 16#'s
Maxxed my stock pumps/BAP so didn't go any higher
Old Jan 13, 2011 | 02:34 PM
04svtcobra16
I have came across a 2.4 KB for a killer of a deal, how does it compair to the 3.4 Whipple?
Old Jan 13, 2011 | 03:00 PM
mfj's Avatar
mfj
Banned
It doesn't compare to the 3.4 whipple lol.
Old Jan 13, 2011 | 03:03 PM
SaddleUp's Avatar
SaddleUp
From what I read, Kenne Bell's seem to be more tempermental than the Whipple. Both give good hp results however. I've known diehard KB believers, but even he had a couple of major issues with his.
