SVT Forums
Oil cooler leaking...
Old Mar 1, 2011 | 09:56 AM
87fordgt's Avatar
87fordgt
Default Oil cooler leaking...
After many months of confusion, I've learned that my oil cooler assembly is leaking out of a "weep" hole in it from the factory. 99 Cobra by the way. Here's what nobody can seem to tell me, Why is it leaking? I would just replace it, but the part is freakin' $410 from ford and only a little cheaper elsewhere, AND there's no guarantee that'll fix it. The dealer says they've never heard of the issue. I could take it off and have it tigged shut, but if the hole is there for a reason, then I figure I better find out what the issue is first. Any ideas? I'm at a loss at this point. I'm about to give up. Here is the part number for the exact part that leaks. F8ZZ6A642BA. I just need to know why the weep hole is releasing oil, and what I can do to fix it, or what happens when I just plug the hole. One more tidbit of info, this hole was plugged up when I bought the car unannounced to me. So I drove it over 500+ miles before the patch let loose with no issues.
Old Mar 1, 2011 | 07:04 PM
Blackvenom01's Avatar
Blackvenom01
hmmm thats interesting i have never seen a weap hole there is an o-ring that is between the oil cooler and oil cooler adapter...those go out alot everyone of my buddys had to replace theres not to mention hearing bout many others...im curious if its just the o-ring leaking and making it seem like its coming from a hole?
Old Mar 2, 2011 | 05:20 AM
uberstang1's Avatar
uberstang1
Chupacabra
There was another memeber a few months back with the same issue, it was infact a weep oil that was leaking oil out from the bottom of the housing. I also replaced mine, which was only a seal, cause I was told by ford the seal wasn't replaceable which was in fact a lie. But if its OIL leaking from the weep oil I would replace the unit, if the seal was bad it would be leaking from the seal I would imagine. Weep holes are designed for a reason, just like a water pump. If fluid comes out of the weep hole that usually indicated internal damage, bearing play, or something similar.
Old Apr 15, 2011 | 06:31 PM
disposablehero27's Avatar
disposablehero27
I do believe i am having the same problem in my 96, it is leaking from the hole, and from the adapter behind it. Its possible i thought it was coming from the whole when it was lightly leaking from behind it. So once i take the engine out, i assume my new engine won't come with another one, you suggest plugging the hole is a bad idea? i can replace the o-ring... not a problem.
Old Apr 16, 2011 | 12:26 PM
87fordgt's Avatar
87fordgt
Don't plug it. If it's coming out of the hole, there's something wrong. All I did was take the oil filter off, get a .5 inch hex head socket and ratchet and tighten the shaft that the oil filter screws onto. Done. No more leak. The weep hole was just letting me know something was wrong. Hasn't leaked again since.
Old Feb 13, 2015 | 02:33 PM
nmwhitco's Avatar
nmwhitco
Default Where is the weep hole
I have oil running down the side of the cooler and off the bottom near the middle. I can't see the top of the cooler. Where is the weep hole located at? Can i see it with the cooler on the car?
jwog666
Dec 27, 2021 08:09 PM
SSRFUZZY
Members Other Vehicles
Jan 6, 2016 08:22 PM
wraith777
Sep 28, 2015 10:49 AM
belam
Oil and Oil Related Topics
Sep 23, 2015 11:29 PM
Demodulates
Sep 18, 2015 11:14 AM
