SVT Forums
Cobra power window failure
Old Aug 29, 2005 | 01:28 AM
Texas Denny's Avatar
Texas Denny
Default Cobra power window failure
I've got a 2001 Cobra. The driver side power window is down and won't respond. I think I need to get the window up to replace the motor. Is there a way to raise the window manually? Thanks,
Old Aug 29, 2005 | 03:05 AM
Jugador's Avatar
Jugador
Default RE: Cobra power window failure
try posting this in general tech or the 4.6 section for better results. this section is for issues about the forum itself
Old Sep 27, 2005 | 05:34 PM
snellingtw's Avatar
snellingtw
you can still get the window motor out with the window down. i'm pretty sure that even when the window is all the way down its still above the motor. and once you get the motor out you can just push the glass up with your hand. i've had to replace mine a few times on my 97 cobra. but before you take the motor out make sure that its still plugged into the relay if its the drivers window. its got that relay for the automatic roll down. if its not plugged in the motor doesn't work at all.
SSRFUZZY
Members Other Vehicles
Jan 6, 2016 08:22 PM
Nov 10, 2015 11:39 AM
1TUFF302
Nov 5, 2015 04:02 PM
rdog69t
SVT Forums
Sep 13, 2015 06:16 PM
Sparks_88
Sep 8, 2015 01:06 PM
