SVT Forums
What would you do?
Old Jan 21, 2012 | 11:02 AM
01Cobra3531's Avatar
01Cobra3531
Default What would you do?
Well, I had a question as to what everyone would do for their Cobra if you weren't gonna be able to drive it, or even start it from 7 months up to a year? What I'm asking is would there any special steps you would do to keep the engine and everything good for that time period? The reason I'm asking is because I'm going to be going to Afghanistan in the near future.
Old Jan 21, 2012 | 02:51 PM
Blackvenom01's Avatar
Blackvenom01
find a trusted friend or family member and have them start it atleast once a month let it run till is good and hot hit the gas a few times to get the moisture out and soon as you get back do an oil change before you drive it cause you will collect condensation in the oil if its not driven hot enough to burn the water out
Old Jan 21, 2012 | 03:33 PM
DRAGUL's Avatar
DRAGUL
I usually store mine about 5 months during winter. First I wash and wax it. Then I use stable in the gas. Cardboard under the tires. Hook battery tender up to the battery. Then the car cover goes on. It does however get a oil change when I take it out of storage.
Old Jan 22, 2012 | 09:47 AM
Blackvenom01
as you might know the problem with letting it sit so long is the oil running out running all down to the pan virtually making it a dry oil free start which is rough...if mine sat for 7months totally untouched id pull the valve covers pour oil over top let soak in then start...thats just me not wanting to jack my engine
other people say turn the key multiple times with the gas floored to pump up the oil pressure dunno if that works or not but its an option
Old Jan 22, 2012 | 10:47 AM
redneck racer's Avatar
redneck racer
Ive also heard removing the plug wires and turning the motor over without the wires attatched will help re-lube everything without the car actually cranking. Ive never had to leave mine that long, but if you do have someone to crank the car for you and let it run every month or so that would be the best option.
Old Jan 30, 2012 | 07:02 AM
05 Mustang's Avatar
05 Mustang
+1^^
I don't usually don't have to store mine being in Georgia...but the above is what I hear most folks up North doing....only thing I'd do differently is put carpet under the tires...
Old Jan 31, 2012 | 04:56 PM
DRAGUL's Avatar
DRAGUL
Carpet under the tires, interesting.
