SVT Forums
04 Cobra whiple 2.3 our 2.9
Old 02-18-2012, 11:29 AM
redneck racer
redneck racer's Avatar
2.9 you have to run a single blade TB i believe. I was running a 3.5 upper stock lower. Aparently they make different boost #s on different setups, but i was only seeing 16-17psi with it, some claim 18.
redneck racer is offline
Old 02-18-2012, 03:42 PM
cobra21987
cobra21987's Avatar
What would I make with a 2 pound lower and stock upper
cobra21987 is offline
Old 02-18-2012, 05:25 PM
redneck racer
3.5 is the stock upper, so probably 18-20lbs. Thats about the max you will be able to run with pump gas.
Old 02-18-2012, 05:44 PM
Blackvenom01
Blackvenom01's Avatar
i would change the upper before the lower cause thats when you start running into belt slippage issues my 3.0 upper runs at 20 psi and 21 with meth
Blackvenom01 is offline
Old 02-18-2012, 05:50 PM
redneck racer
I agree, i ended up grabbing a 3.2 and 3.0 pulley for my 2.9 thise go around. I dont really like the whole lower pulley thing unless you are running a eaton.
Old 02-18-2012, 06:06 PM
cobra21987
cobra21987's Avatar
How much horse roughly with 19 to 20 pounds on a 2.9
cobra21987
cobra21987's Avatar
also is 3800 a good deal with the 2.9whipple and accufab throttle body shipped
Old 02-19-2012, 10:05 AM
Blackvenom01
idk how efficient the 2.9s are i havent been around them enough to know...my guess would be mid to upper 600's...assuming they make more power with less psi then the 2.3...but i do know that they can boost higher too so they may not be that much more efficient it might just give you more safe room to boost it up high
i havent looked into them much to know pricing but i thought they came new like 5k??
Old 02-19-2012, 12:22 PM
redneck racer
Thats a good price. I paid around 3700 new for my 2.9 without the TB. You should see mid to high 600s in the 19-20lb range depending on a few other things.
Old 02-20-2012, 07:26 PM
cobra21987
cobra21987's Avatar
I think im gonna go with the kenne bell 2.8 bro
Quick Reply: 04 Cobra whiple 2.3 our 2.9
