SVT Forums
Needing help identifying this...
Old Nov 20, 2012 | 01:47 PM
Throttlehog's Avatar
Throttlehog
Question Needing help identifying this...
My 99 Cobra has started leaking oil and a preliminary trace has led me to the area of the oil cooler adapter. If I were to hazard a guess, it looks like the oil pressure sending unit might be the culprit; however, it's also possible it's coming from the "port" located directly below the sending unit. Does anyone have any idea what this is? I've checked my Haynes manual (pretty useless for Cobra), as well as Ford's shop manual and can't find any reference to it.
Also, the Ford shop manual doesn't indicate draining the oil before removing the sending unit and that just seems crazy to me , but if I can get away with not draining it, it would save me buckets of time - anybody ever remove it with oil still in the motor?
Old Nov 20, 2012 | 02:18 PM
Throttlehog
Sorry, forgot to post this with question...
http://flic.kr/p/duSZkM
Old Nov 20, 2012 | 09:03 PM
BraMas's Avatar
BraMas
That is an extra hole to add stuff like a aftermarket Oil pressure gage or even oil temp. And why is it "crazy" to you that you do not have to remove the oil to change the sending unit?
Old Nov 22, 2012 | 08:20 AM
Timspony's Avatar
Timspony
SVT Section Moderator
I did remove the plug to put in a Auto Meter oil pressure gauge...I little oil came out, that's all....
Old Apr 8, 2013 | 10:38 PM
rag-top_man's Avatar
rag-top_man
I have had both the sending unit leak at the crimp to the plastic and the adapter to the block leak (at different times). the adapter leaked where it was bolted to the block its a plastic gasket with RTV type o rings embedded into it cost was less than 20.00 but a pain to change as there is 1 hidden bolt(all 10mm size) 1/4 drive ratchet set made it go reasonably easy. then 6 mos later the sender started leaking! easy to change. I lost a small amount of oil on both projects. clean the area at the car wash to determine which is leaking .
Old Apr 23, 2013 | 10:27 PM
Throttlehog
Thumbs up Sending unit was the culprit...
...and all I had to do was run a nice little bead of high temp rtv at the top of the threads, and I'm no longer finding oil spots in the driveway. Of course I did this back when I first posed the question and just now got around to reading the replies...still, I appreciate your replies nonetheless...
Urambo Tauro
Dec 17, 2016 03:30 PM
dba Brakes
Aug 23, 2015 08:16 PM
defarmer
Aug 13, 2015 06:40 AM
Super_Chief
Aug 11, 2015 03:54 AM
teeeeg67
Aug 6, 2015 09:41 AM
