SVT Forums
IRS Question
Old Sep 8, 2013 | 05:27 PM
projectresto83's Avatar
projectresto83
M.A.D. Motorsports
Originally Posted by Martel
Those are 03-04 cv shafts. As to the rest of it who can say for sure. 03-04s also came with a front differential torque brace.
http://fulltiltboogieracing.com/FT%201290.htm
Then I will take that as a yes this is a Termi rear end lol. Thanks. Now I know I need to find a Termi driveshaft or at least the conversion for that yolk.
Now I just need to get my 83 in so I can get it under the car and out of my garage. I am going to trim stock fox springs down so I can at least have it under the car...not to be driven...
Old Sep 9, 2013 | 11:37 AM
99 GT vert's Avatar
99 GT vert
I have a complete center section from an 04 cobra what dimensions do you want?
Old Sep 9, 2013 | 01:27 PM
projectresto83
M.A.D. Motorsports
the pinion flange diameter and the measurement of the spread of the bolt holes.
Thanks
Old Sep 9, 2013 | 02:52 PM
BraMas's Avatar
BraMas
Thanks
Did you not see my post on how to avoid using the IRS pinion flange?No conversion kit is needed
Old Sep 9, 2013 | 05:43 PM
99 GT vert's Avatar
99 GT vert
pinion flange diameter is 5 inches and the bolt separation is 3 inches
Old Sep 10, 2013 | 02:41 PM
projectresto83
M.A.D. Motorsports
assuming you measured the bolt spread from the bolts that side by side and not across....then mine is the same.
Old Sep 10, 2013 | 02:46 PM
projectresto83
M.A.D. Motorsports
Originally Posted by BraMas
If your wondering if the pinion flange is different than a SRA the answer is yes. Just put the pinion flange from the SRA on the IRS and your DS will bolt right in. This is what I did for my swap.
And stop calling it a "Termi" it's Terminator "termi" makes the car sound gay
Now I see your post, skipped right over it. Thanks.
I was more curious on the measurement to be sure it was a TERMI IRS, not specifically for the TERMI driveshaft.
As for swapping in the SRA pinion flange, I still don't know if the fox length driveshaft will work yet nor have I completed that much research about it. If I have my way about it, once this project begins I will be using a FRPP aluminum shaft. I am not exactly in a rush to install this because I have work to do to the underside of the fox and bushings to swap out before I do so.
Dokilar
15
Oct 16, 2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
ChampInSD
Oct 2, 2015 04:55 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
