i blew my 95 cobra engine with a little too much nos and replaced it with a 5.0 non cobrarebuilt engine. i dont' have the throttle responce or power that i am expecting out of the engine and am wondering if there are some computer issues or something else that i am not thinking about. any help will be appreciated.</P>
i know the difference btw the 2 engines. i had this one built. i didn't pull it out of a gt. it should perform better than the original cobra engine that came in it.
yoU MIGHT HAVE TO GET TO ECU TUNNED. Did you use the same injectors. The Cobra motor used 24lb. injectors. If you didn't use them. And the ones that were in the regular 5.0 motor were only 19lb. injectors. If thats the case your mass air meter is messed up. And you should put the 24lb. injector form the orginal motor in.
yeah same injectors. its an older engine probably 70's but it was professionally built with good pistons and cam and all ill post details later. it just seems like there is something im not thinking about. poor throttle response leads me to think there is a fuel air problem. any more ideas?
