SVT Forums
Upgrades for a 98 Cobra
Old Jan 23, 2006 | 11:53 AM
MuscleOwnzRice's Avatar
MuscleOwnzRice
Default Upgrades for a 98 Cobra
Could someone help me out PLEASE?!?! Could someone give me a short listing of a few modifications done to cobras to make them quick, in order if possible. Also whats a good company to get gauge bezels for columns and such from??? PLEASE HELP!!!
Old Jan 23, 2006 | 01:34 PM
Black04COBRA's Avatar
Black04COBRA
Default RE: Upgrades for a 98 Cobra
Same things as your GT.
Gears, intake, exhaust, some good rubber.....and it just gets more in depth from there.
Old Jan 23, 2006 | 06:48 PM
7arpad7's Avatar
7arpad7
To add to the gears, exhaust (headers, x-pipe w/no cats or high flow), K&N air filter (the cold air kit is not really worth the extra money), and then under-drive pulleys (be careful to make sure that the underdriven alternator pulley will give you a full charge at idle, you may just omit this one to save the hassle). You can also relocate the battery to the trunk (it is relatively cheap and you gain traction while lowering the weight in the front of the car so the winning is thrice). Depending on the wheels that your car came with, you can get lighter/wider ones for more traction and less unsprung weight. On that note...an aluminum drive shaft is relatively cheap and further helps you get those available horses to the pavement. Another relatively inexpensive mod is a short throw shifter (it makes a bit of a difference no matter how fast you can shift). After all of this, the mods do become expensive and complecated. I will be interested in hearing how it all works out.
Good Luck!
7arpad7
Old Jan 30, 2006 | 12:22 AM
MuscleOwnzRice
Thanks, im goin to look into all that in more depth. Appreciate the help greatley
Old Jan 30, 2006 | 05:07 PM
Cobra2497's Avatar
Cobra2497
If you want the best man
www.seanhylandmotorsports.com
Call them guys up and tell them how much you want to spend.
If you are not good with cars I would not do the gear thing first.
Go small
Computer, Air Intake, X-Pipe.
But call them they are the best in the 4.6 world.
PaulH2
20
Jan 31, 2016 09:48 AM
88 orangepeel notch
Oct 5, 2015 09:03 AM
Boostaddict
Lethal Performance
Oct 1, 2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
Oct 1, 2015 08:57 AM
UrS4
Sep 30, 2015 10:13 AM
