The Racers Bench Is the track just too much for you? Want to know what will beat what? Talk about it here!!
It Doesn't Look Like Much.
Old Aug 9, 2010 | 06:00 PM
crash's Avatar
crash
BrandofPoop
^And we need vids of your new beast!
Old Aug 9, 2010 | 08:18 PM
VistaGT's Avatar
VistaGT
Originally Posted by Stkjock
we need a bigger picture
LOL!
Good luck with the new trans, looks purdy
Old Aug 9, 2010 | 08:21 PM
83gtragtop's Avatar
83gtragtop
Good luck, does this mean you will still be running it in 1/4 or are you going to explore road courses.
Old Aug 10, 2010 | 12:53 AM
67mustang302's Avatar
67mustang302
This is something to keep in mind, and should help you sleep better at night, as far as transmission ratings.
The ft-lb or hp ratings that engineers give to a transmission, is the maximum CONTINUOUS input that the transmission can hold for a specified length of time(service life at full load). No one knows the actual length of time except the trans engineers, but generally it's pretty absurd, like in the tens of thousands of hours. So assuming proper lubrication and temperature, a trans rated for 600lb-ft at the wheels, will hold that much power for something like 40,000hours continuously(assuming lube and temp remain up to snuff). They can handle short bursts from shock load much higher than the rating(and indeed when hard shifting occurs the shock loading puts FAR more stress on the trans than the engine can).
More power output and that expected life drops, less power output and it lasts longer. And when you consider than most of the driving for a street car you're producing very little power......you see where that goes. As a for instance, the TKO 600 I have in my Mustang is rated as 600lb-ft at the transmission by TREMEC....but they've run season after season after season behind engines producing 1,000-1,500hp, and I've never heard of anyone actually breaking one from too much power.
Assuming the case for the trans is up to it, and it's properly maintained....if you're producing 600lb-ft or less at the wheels, chances are that trans will outlive your car in street/strip use.
Old Aug 10, 2010 | 02:47 AM
bluebeastsrt's Avatar
bluebeastsrt
I still plan on doing both. The roadcourse autocross is alot of fun and believe it or not not my skittle is actually better set up for that. We all know it's the worst drag set-up there is.
I didn't know any of that. I sure hope that last statement is true.
Old Aug 10, 2010 | 02:50 AM
bluebeastsrt
You would think the Mustang forum would have the Photo auto size feature like the SRT forum does. I mean theres a jillion Mustangs and on a few knuckleheads when out and bought hoped up neons.
Old Aug 12, 2010 | 04:29 PM
98LS1's Avatar
98LS1
They have small monitors and are hatin on your superb pictures.
Mr I'mnotgonnaspendanymoneyonthisjunkanymore. Good jorb!
Old Aug 12, 2010 | 05:13 PM
bluebeastsrt
Well it's gotta have a transmission or it's just a 3000 pound paper weight.
Old Aug 22, 2010 | 12:42 AM
302army187's Avatar
302army187
nice tran's
just to update the long winded post by 67mustang302, I was told by the people I bought my transmission from that the TKO600, and most other transmissions are rated for a 24 hour period.
So if you could produce 601hp/torque for 24 hours strait, it would probably bust.
They said themselves that the TKO 600's though have lived up to 900hp for years. just like 67mustang302 said. so I think this trans you got is a great investment, and im sure it wasn't cheap! Thats why I went with a beefed up T5 instead of a tko600, it was to much money for me
kevsgt
Oct 9, 2015 10:12 PM
Dathan
Oct 5, 2015 05:52 AM
treesloth
Sep 28, 2015 07:03 AM
Offendant
Sep 23, 2015 07:21 PM
algregory
Sep 11, 2015 11:44 AM
