The Racers Bench Is the track just too much for you? Want to know what will beat what? Talk about it here!!
Roush Supercharged 2016 track times
Old 06-09-2017, 08:55 AM
caneboy
caneboy's Avatar
Default Roush Supercharged 2016 track times
Ok so I have a Roush Supercharger, Roush quad exhaust and the Roush single coil overs on my 2016 PP. I have Nitto 555 G2 (305) on the rear. The fastest time i could get at the track was 12.2. Second gear was a waste because I just spun right through it. I know I could break 11 with DR but i dont want to change tires. Any ideas on how I could get a little more traction?
caneboy is offline
Old 06-09-2017, 09:04 AM
99GTvert
is my username.
99GTvert's Avatar
You can try adjusting the tire pressure a little bit by a few pounds. With that much torque though you would be much better off with stickier tires.
How does the car feel at the track? What's the trap speed?
99GTvert is offline
Old 06-14-2017, 09:04 PM
darkmach1
darkmach1's Avatar
Go to another track that's prepped or learn to slip the clutch.
darkmach1 is offline
Old 06-17-2017, 09:18 PM
outceltj
outceltj's Avatar
just spend the money on the slicks. Other wise you won't get very good times
outceltj is offline
Old 06-18-2017, 12:36 AM
AK_Kayaker
AK_Kayaker's Avatar
If you do go with stickier tires, you had better get upgraded half shafts, if you don't already have them.
AK_Kayaker is offline
Old 06-20-2017, 11:36 AM
88 orangepeel notch
88 orangepeel notch's Avatar
Just no way around it. At that power level, a street tire just isn't going to bite hard enough.
88 orangepeel notch is offline
Old 09-04-2017, 06:43 AM
Buck Sergeant
Buck Sergeant's Avatar
CANEBOY, I suspect part of your traction problem is not having enough weight transfer. Try a set of front adjustable struts and rear adjustable shocks. I prefer, at 16 psi hot, the NITTO NT05R shoes. All the other suggestions will also be very useful.
Buck Sergeant is offline
