Tuner Central Have a question about which hand tuner is best for your Mustang? Talk about it here!
Incorrect speedo reading U7146 tuner
Old Oct 17, 2010 | 11:14 PM
Z28KLR's Avatar
Z28KLR
Default Incorrect speedo reading U7146 tuner
So today I went to change from "performance tune" to "factory HP tune" so I can go back to 87 octane for a little while. I modified parameters with the factory hp tune the same as was the performance tune (all OBD-II except for egr switch turned to off because of my o/r midpipe, and set axle ratio to 4.09).
For whatever reason the speedometer reads approximately 20-25 mph faster than actual speed. I double checked all of the modified parameters just to make sure, even restored factory tune and then reloaded the "hp tune" (made sure it was set to "manual trans") and modified the parameters again as mentioned above with the same results.
Long story short, for now I just reloaded the performance tune with modified parameters and everything's good again, but I'd like to know what's up with the "factory HP tune" axle ratio parameter not working as it should.
Old Oct 18, 2010 | 10:22 AM
Mike@DiabloSport's Avatar
Mike@DiabloSport
Premium Sponsor
You running the latest revision?
Old Oct 18, 2010 | 01:55 PM
Z28KLR's Avatar
Z28KLR
No, I was unaware that there were any software revisions or updates. I'll check Diablosport's site and see what I can find out.
Old Nov 8, 2010 | 08:54 AM
Brodiemannn's Avatar
Brodiemannn
Im having the same problem, where can i check the revision?
Old Nov 8, 2010 | 01:53 PM
Mike@DiabloSport
Premium Sponsor
Top line of the main menu on the Predator screen.
04stangman
Sep 17, 2015 01:45 PM
nboost
Sep 16, 2015 05:35 AM
Daddys Girls GTs
Sep 14, 2015 08:46 PM
MasterLanMan
Sep 13, 2015 08:21 PM
ernesto-619
Sep 10, 2015 01:32 AM
