Tuner Central Have a question about which hand tuner is best for your Mustang? Talk about it here!
Changing diablo canned tunes?
Old Jan 26, 2011 | 08:06 PM
wws2010's Avatar
wws2010
Default Changing diablo canned tunes?
Hey I was driving today and decided to do a pull. I went to about 50 in my auto and as it shifted it completely spun out the rear tires! I was excited but I just had the 87 tune! Is there any way to adjust the 87 and 93 tune? Like a way to modify them? Cause I live in california and all we have is 91 and I would love to run it to its full potential. I mean is there a way to take a 93 tune as a base point, reduce the timing 2 degrees and then adjust it for my 4.10s and increase the shifting softness at wot?
Old Jan 28, 2011 | 04:20 PM
Mike@DiabloSport's Avatar
Mike@DiabloSport
Premium Sponsor
Yes, you can do exactly what you said in the modify tune menu after you select the tune.
Old Jan 29, 2011 | 12:03 AM
wws2010's Avatar
wws2010
That would make sense! lol didn't see it thanks man! What do you think I should set my shift firmness at for 245 with 4.10s? Is that what you adjust to keep from loosing traction when I shift?
Old Jan 29, 2011 | 03:06 PM
Z28KLR's Avatar
Z28KLR
All cars respond differently of course, but you might not need to back off the timing. I live in CA as well and have not needed to modify the spark timing parameter due to detonation from using 91 octane on a 93 canned tune. Also, the Predator only end-user adjusts for spark timing at WOT, so if you do get any detonation at part throttle you will need changes made to the Global spark table which you'll need a custom tune for.
djbigskrilla
Sep 20, 2022 01:04 AM
mrreynolds80
Sep 19, 2015 07:37 PM
thesambox
Aug 19, 2015 09:39 PM
Daleford
Aug 10, 2015 08:30 PM
dangthatsfast
Aug 6, 2015 09:46 PM
